Heating FeSO4.7H2O: Reasons for Different Values of x
  • Thread starter coconut62
  • Tags
    Heating
In summary, the conversation involves a practical examination question about determining the value of x in FeSO4.xH2O by heating the crystals in a crucible. The value of x was found to be 7, but another student obtained a value of 9, possibly due to some crystals splattering out of the crucible during heating. However, the exact composition of hydrates can vary and FeSO4 is not a stable salt, which may also contribute to the difference in values.
coconut62
161
Yesterday I had a practical examination, and one question involves the heating of FeSO4.xH20 to get rid of the water of crystallization to determine the value of x.
A crucible was used to contain the crystals. Just a few grams.
I had found the value of x to be 7. And now a part of the question says, a student did the same experiment and obtained a value of 9. What could be the reason for this?
I wrote that because during heating some of the FeSO4 crystals "jump" out from the crucible, resulting in a larger mass loss and the mass lost is assume to be the mass of water of crystallization.
Is that acceptable?
Chemistry news on Phys.org
That sounds plausible, yes. I vaguely recall that iron sulphate crystals do crackle as they lose water when heated, so I would expect this may splatter some powder out of the crucible if you were to leave its lid off.
But careless lab technique may not be quite the answer your examiner was looking for. Perhaps he was hoping for ... http://answers.yahoo.com/question/index?qid=20110908041238AAw5ka4
Likes 1 person
Worth of noting here that exact composition of many hydrates depends on the temperature, humidity and sample history (where and how it was stored for the last few hours).
Also, FeSO4 is not a stable salt - iron gets oxidized by the air oxygen to Fe(III), so what you think is FeSO4·7H2O can be in fact a mixture of different sulfates.
Likes 1 person
1. What is FeSO4.7H2O and why is it heated?
FeSO4.7H2O is a chemical compound known as iron(II) sulfate heptahydrate. It is commonly heated to remove the water molecules and create anhydrous iron(II) sulfate, which is used in various industrial processes.
2. Why are there different values of x in the formula?
The value of x in the formula FeSO4.xH2O can vary depending on the temperature and conditions under which the compound was formed. It can range from 1 to 7, with 7 being the most common.
3. What factors affect the value of x in FeSO4.xH2O?
The value of x in FeSO4.xH2O is influenced by factors such as temperature, pressure, and the presence of impurities. Higher temperatures and lower pressures tend to result in lower values of x, while the presence of impurities can also affect the crystal structure of the compound.
4. Is it possible to have a value of x other than 7 in FeSO4.xH2O?
Yes, it is possible to have a value of x other than 7 in FeSO4.xH2O. As mentioned earlier, the value of x can range from 1 to 7 depending on the conditions under which the compound was formed. However, 7 is the most common value due to the stability of the heptahydrate form.
5. What is the purpose of heating FeSO4.7H2O to create anhydrous iron(II) sulfate?
The anhydrous form of iron(II) sulfate is used in various industrial processes, such as water treatment, pigments, and fertilizers. Heating FeSO4.7H2O to remove the water molecules allows for a more concentrated and stable form of the compound to be used in these applications.
