Height equation in a weird way.
  • Thread starter Thread starter daniels.tyler
    Height Weird
The discussion revolves around a hot air balloonist's challenge of determining his real height using an altimeter that displays a height multiplied by an unknown constant A. The balloonist plans to drop two rocks over a canyon and measure the time it takes for the echoes to return, using the equations of motion to calculate the heights of the drops. By recording the altimeter readings at both drops and calculating the difference in heights, he aims to derive the multiplication factor A. The approach assumes that the initial velocity and starting height are zero and that the speed of sound is constant, allowing it to be disregarded in the calculations. The balloonist seeks confirmation on the correctness of his method and equations.
daniels.tyler
A hot air balloonist forgot to calibrate his altimeter before taking off. The altimeter displays his height as A*h (A being a constant multiplcator, and h is his real height). He does not know A, nor does he know the speed of sound. How can he find his height with just two rocks that he can drop over a canyon and listen for their echoes. Neglect air resistance.
y=y0+V0T+.5GT^2
G=-9.81
I assumed V0 and Y0 is equal to 0.
Dt (difference in time) is equal to T2-T1
I disregarded the speed of sound because it is a constant in both drops.
First drop:
y1=-4.905(T1)^2
Second drop:
y2=-4.905(T2)^2
(Dhr)(difference in real heights) is y2-y1=
-4.905(T2)^2+4.905(T1)^2
If I record the heights the altimeter gives me at the two points, and find the difference and then divide that by my (Dhr), I should get my multiplication factor right? That is assuming the equation for the (Dhr) is right.
The question doesn't ask you to find A so you figured out the problem already
So I my equation for A (the multiplaction factor) is correct? It was right of me to disregard the speed of sound?
