- #36
Merlin3189
Homework Helper
- 818
This is his circuit
The two coils are coupled - ie. close together on the same axis. I suppose you'd call the 25 turn coil the primary and the 90 turn coil the secondary, since that is the direction of the signal path and power flow, but it does not have any significance IMO.
The 90 turn coil is the tuning coil equivalent to the 200 μH inductance in your circuit. The 25 t coil is to couple the signal from the antenna into the tuned circuit.
I'm not sure what you are asking here, "what doe mean, when they say primary coil 200micro, and what about secondary? they don't say nothing about secondary?" As far as I can see, your first diagram makes no reference at all to primary nor secondary and it is IMO immaterial anyway. In the video of the crystal set, he talks about the primary and secondary, but does not mention any inductance value - he is just working by guesswork (probably well-informed guesswork).
I think it is unhelpful to worry about primary and secondary here. You are not designing a transformer and probably don't have enough information to do so.
The large coil - the 200 μH in the first circuit, the 90 turns in the second circuit - is the important one. It needs to have the correct inductance to match the tuning capacitor for the frequency you want to receive. 200 μH with 500 pF resonates about 500 kHz, the low frequency end of the medium wave band. As the capacitance is reduced, the resonant frequency increases to about 1.6 MHz at the high frequency end of MW band when the capacitance is down to 50 pF.
The smaller coil could possibly be calculated, but it depends on the aerial used and the construction of the main coil and position of the small coil. The 4-5 turns of the first circuit and the 25 turns of the crystal set are probably educated guesses or trial and error values. The first circuit appears to have a much higher turns ratio than the crystal set, which will reduce the aerial loading on the tuned circuit and give a higher Q to sharpen the tuning. I'm not sure why the crystal set has a lower ratio,
Aside from your question, I would very much agree with Baluncore in #33. Get the straightforward circuit working, before you start the modifications.
Stay with making your own coil: it will be much better than the inductor designed for blocking or damping RF and it is really quite easy to do. If you don't get exactly the right inductance, that won't matter much: you'll just get a different tuning range. (And you can then have another go at winding a coil, using the same wire and tube knowing proportionally how many turns more or less you need. Or if the coil is air cored, you may simply be able to add a core.)
