HELP A rolling without slipping problem
In summary, the cylinder rolls without slipping due to the frictional force acting on it. The net torque due to the forces acting on the cylinder is equal to the applied force minus the frictional force.
Kudo Shinichi
109
HELP!A rolling without slipping problem
A solid cylinder of radius R and mass M has a string wrapped around it and is placed on its side on a horizontal surface. The free end of the string is pulled horizontally with a force F as shown in the figure. As the string unwraps, the cylinder rolls along the surface without slipping.
a) show that the acceleration of the center of mass is given by a_cm=4F/3M
b) what is the magnitude and direction of the frictional force acting on the cylinder?
c) what is the acceleration of the free end of the string?
diagram:
http://tinypic.com/view.php?pic=2qsw4kj&s=4
V_cc=0 and it is the velocity at reference frame of center to center
a) accelertaion of CM:
A_tot=sqrt((atan)2+(ac)2)
=sqrt((R*alpha)2)2+(R*(Vcc)2)
because vcc=0 therefore A_tot=R*alpha
4F/3M=4(M*alpha)/3M=4/3*alpha and R=4/3 in this case
b) the frictional force opposite to the applied force, and it is equal to the applied force, which is equal to M*alpha
c) the acceleration of the free end of the string would be same as the acceleration of the cylinder, which is R*alpha
I am not sure whether I did the problem correctly or not, can anyone help me with it? thank you very much.
I can't follow your solution. Why not start with the basics? Draw a free body diagram and apply Newton's 2nd law to both translation and rotation.
i tried but how can I related the force to CM?
the angular velocity for CM is omega and alpha is the angular acceleration around the cylinder
What I know now is mass of the cylinder. Even though I also know the acceleration but it is not for center of mass.
Using Newton's 2nd law for translational motion: Fnet = macm, where acm is the acceleration of the center of mass.
Do you mean that acm=F/m, which I could use to should for part a. Sorry but where did 4/3 come from? is it part of the acceleration?
Kudo Shinichi said:
Do you mean that acm=F/m, which I could use to should for part c.
Yes, but the force you need here is the net force, not just the applied force "F". That's why I wrote Fnet.
What individual forces act on the cylinder?
The 4/3 will appear when you solve for the acceleration. As I said earlier, you'll need to apply Newton's 2nd law twice: for translational motion and for rotational motion.
since it is a rotational motion there is [tex]\alpha[/tex] for this equation,
The 4/3 will appear when you solve for the acceleration. As I said earlier, you'll need to apply Newton's 2nd law twice: for translational motion and for rotational motion.[/QUOTE]
net force=F-Ffr=F-[tex]\mu[/tex]*FN=macm
the above is the translational motion, sorry but how can i get rid of [tex]\mu[/tex]
net force=F-Ffr=F-[tex]\mu[/tex]*FN=m*[tex]\alpha[/tex]
there is a new variable appears in this equation,[tex]\alpha[/tex], which we can write it as r/a
i think what i can do next after i know how to get rid of [tex]\mu[/tex] is set the two equation equal to each other and solve then we will be able to get 3F/4M
is it right?
You don't need to use μ, just leave the friction force as Ffr. In what direction does the friction force act?
The second equation you need is Newton's 2nd law for rotation: [tex]\tau = I \alpha[/tex]
frictional force is equal and opposite to the applied force
I can write I as 1/2mR2 and [tex]\alpha[/tex] as R/acm
therefore, [tex]\tau[/tex]=(1/2mR2)(R/acm)
or there is another way to describe [tex]\tau = I \alpha[/tex], which is [tex]\tau[/tex]=radius*force, which is equal to radius*macm
Careful. [tex]\alpha = a/R \ne R/a[/tex]
I suggest that you find the net torque due to the forces acting on the cylinder.
Doc Al said:
Careful. [tex]\alpha = a/R \ne R/a[/tex]I suggest that you find the net torque due to the forces acting on the cylinder.
do you mean use the latter equation to solve(torque=radius*F)?
and by the way, I think that I have inserted my answers for the previous question into the qutation just now...
about the frictional force, it is equal and opposite to the applied force.
If I use the first equation I wrote for torque then torque=(1/2mR2) (a/R)=1/2ma*R=1/2F*R
How do we connect this equation with F-Ffr=macm?
What torque is exerted by each force acting on the cylinder? What's the net torque?
No. If friction were equal and opposite to the applied force, then the cylinder would not accelerate.
This is OK up until the last step. Note that F is just one of the forces acting on the cylinder.
You still need to find the net torque.
If there is just one force applied on the system then isn't there just one torque? which means that the net torque is equal the only torque, which is r*F? Sorry, I am a bit confused...because in order to have net torque you need to have more than one force
Or do should I also include the frictional force?
then the net torque would be r*Fsin[tex]\theta[/tex]+r*Ffrsin[tex]\theta[/tex]
Sorry again...how do we find the angle for sin?
Of course you should include the friction force. (For both translation and rotation.)
First things first: Which way do the forces act?* Draw the forces on your diagram. Since both forces are horizontal and tangent to the cylinder, the only angles needed are 90 degrees.
*You still haven't figured out which way the friction acts. Note that friction always opposes slipping between surfaces.
the free body diagram I drew
http://tinypic.com/view.php?pic=i4h2ed&s=4
As you said the friction is indeed opposes to the slipping direction
Or am I wrong on drawing free body diagram?
You have the direction of the friction wrong. Friction opposes slipping between the bottom of the cylinder and the floor. If there were no friction, the cylinder would spin clockwise thus the bottom of the cylinder would tend to slip to the left against the floor. Friction on the cylinder opposes that slipping, thus it acts to the right.
OH!that's why
since the direction of Ffr and applied force are the same
then the translational motion: F+Ffr=macm
the rotational motion:r(F+Ffr)=1/2maR2
F+Ffr=1/2maR
then how do we relate these two motions together?
sub translational motion into the rotational motion: r(macm)=1/2maR2
or set these two equations equal to each other
1/2maR=macm
but then we still can't relate it to 4F/3M
Kudo Shinichi said:
OH!that's way
Good.
F+Ffr=1/2maR
Redo this one. Does the torque due to each force act in the same direction? (And be careful with the Rs.)
Once you get the two equations correct, you'll have two equations and two unknowns (Ffr and acm). You can solve them together.
Doc Al said:
Good.
Sorry I don't really get what you mean by torque acting on the different direction. If Ffr has the same direction as F and the angles for sine are equal then why do they have different direction
Just a bit ahead of myself, if there are two unknowns then do we use the sub one equation into another or do we set both equations equal to each other?
One acts at the top of the cylinder, creating a clockwise torque; the other acts at the bottom, creating a counter-clockwise torque.
Combine them to eliminate one of the variables. Substituting one into the other would work.
R(F-Ffr)=1/2maR2
F-Ffr=1/2maR
this is for the rotational motion
F+Ffr=macm
Sorry, I can't find any way to combine these two equations into one...can you help me with it?
Kudo Shinichi said:
R(F-Ffr)=1/2maR2
F-Ffr=1/2maR
The right hand side has an extra R. Remember that [tex]\alpha = a/R[/tex].
F+Ffr=macm
Good.
Be careful with notation. Use the same symbol for acceleration in both equations: a = acm.
Just add the two equations and see what happens. (After you correct the rotational motion equation.)
FAQ: HELP A rolling without slipping problem
1. What is a rolling without slipping problem?
A rolling without slipping problem is a physics problem that involves an object rolling along a surface without slipping. This means that the object's point of contact with the surface is not sliding or slipping, but rather is in constant contact with the surface as it rolls.
2. What factors affect rolling without slipping?
The factors that affect rolling without slipping include the mass and shape of the rolling object, the coefficient of friction between the object and the surface it is rolling on, and the rotational inertia of the object.
3. How is rolling without slipping different from rolling with slipping?
In rolling with slipping, the object's point of contact with the surface is sliding or slipping, resulting in a loss of energy and a different type of motion. In rolling without slipping, the point of contact remains in constant contact with the surface, resulting in a more efficient and controlled motion.
4. How do we calculate the velocity of a rolling object without slipping?
The velocity of a rolling object without slipping can be calculated using the equation v = ωr, where v is the linear velocity, ω is the angular velocity, and r is the radius of the rolling object.
5. What is the significance of rolling without slipping in real-life applications?
Rolling without slipping is important in many real-life applications, such as in the design of wheels and tires for vehicles, the movement of gears in machinery, and the motion of sports equipment like balls and wheels. It allows for efficient and controlled motion and reduces the risk of slipping or sliding, making it a crucial concept in engineering and physics.
