Help Calculating Definite Integral
realism877
(2(x)^2)/((x+1)((x)^2+1)) from 0 to 1
The indefinite answer is (1/2)ln2+ln2-(pi/4)
How did it get to this answer?(3/2)ln2-(pi/4)
Use partial fractions to write the integrand as
\frac A {x+1}+\frac{Bx+C}{x^2+1}
I did that.
I already have the solution. I'm just trying to figure out where the 3 came from.
Oh my! I thought you had a calculus question about integrating. Instead you have an elementary algebra question. See if you can figure out how to combine like terms and make your answer agree with the given answer.
What do you mean the indefinite answer? Where are the x's?
You will need to show us your work in how you got to your answer. You might have made an error in your work.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
