Help check over my answers to these simple questions
  • Thread starter Thread starter SoulInNeed
The discussion confirms that the answers provided to the questions are correct. It emphasizes the importance of including actual examples to illustrate the concepts. Specific examples given include a car moving south with wind moving in the same and opposite directions. It also notes that for the resultant magnitude to be less than 4m, the angle between the two vectors must not be zero. Overall, the responses validate the correctness of the answers while highlighting key vector principles.
SoulInNeed
EDIT: Thanks!
1: Correct.
2: Don't you want actual examples?
a: A car moving directly south at 2m with wind moving directly south along with it at 2m.
b: A car moving directly south at 2m with wind moving directly north against it at 2m.
c: This cannot happen.
3: Correct.
They all look correct to me.
Though for the magnitude to be less than 4m you can say the angle between the two vectors should not be zero. Or the vectors should like at an angle θ.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
