Help Designing Digital Elevator Simulation
The discussion centers on designing a digital elevator simulation circuit that accepts inputs from four momentary push buttons for selecting levels 0 to 3, with outputs displayed on a seven-segment LCD and corresponding LEDs. Key considerations include debouncing the switches, synchronizing inputs with a system clock, and potentially simulating elevator movement time. Participants emphasize the importance of creating a state diagram and understanding state machines, specifically Mealy and Moore types, to manage output states effectively. Resources such as "The Art of Electronics" are recommended for further learning, particularly on switch debouncing and synchronizer circuits. The conversation highlights the need for a clear understanding of the concepts covered in class to successfully tackle the design project.
sndp_2002
I need some help designing a Digital elevator simulation using multi media logics. I need some help and guidelines as to how I should get the thruth diagrams, kmaps and the circuit going.
I am required to design a digital circuit which has applications in elevator style controls. My circuit will ne able to accept 4 momentary closed switches (push buttons) as input, for selecting one of four levels (i.e. 0, 1, 2 & 3). The output of the circuit will be the value of the presently selected level on a seven (7) segment LCD display. Additionally, my circuit should light one of four (4) LEDs corresponding to the push button which is activated. The circuit must maintain the state of all outputs even after a push button is released; only changing state when another button is activated. The circuit should be robust enough to cater for the possibility of several buttons being simultaneously activated by only registering the highest level of those selected.
Please help me
First, you will need to debounce the switches. Do you know how to do that? Then you will need to synchronize these switch inputs with a system clock. Have you learned how to do that yet? Are you supposed to have any real-time delay in this circuit to emulate the time it takes for the elevator to move between floors, or are you supposed to just make the movement instantaneous?
You should draw a state diagram that shows how the outputs change according to the previous state and the inputs. Have you learned about Mealy and Moore state machines yet and how to design them? Quiz question -- what's the difference between those two types of state machines?
I am suppose to design the circuit and then simulate it in the multimedia logic software.. I have not covered the areas you mentioned above. I don't know where and how to begin
Thank you for responding
It's hard to believe that they have given you that assignment without any classroom or textbook instruction to enable you to tackle the design. What have you been learning in that class and related classes so far?
Here's a note from wikipedia.org about asynchronous systems like your elevator controller (asynchronous because the buttons can be pushed at any time with respect to the system clock):
from http://en.wikipedia.org/wiki/Digital_circuit
wikipedia.org said:
In comparison, asynchronous systems are [challenging] to design because all possible states, in all possible timings must be considered. The usual method is to construct a table of the minimum and maximum time that each such state can exist, and then adjust the circuit to minimize the number of such states, and force the circuit to periodically wait for all of its parts to enter a compatible state. (This is called "self-resynchronization.") Without such careful design, it is easy to accidentally produce asynchronous logic that is "unstable", that is, real electronics will have unpredictable results because of the cumulative delays caused by small variations in the values of the electronic components. Certain circuits (such as the synchronizer flip-flops, switch debouncers, and the like which allow external unsynchronized signals to enter synchronous logic circuits) are inherently asynchronous in their design and must be analyzed as such.
Here is some info on state machines from wikipedia -- you should understand the basics of state machines first, and then apply that to the design of your elevator controller:
http://en.wikipedia.org/wiki/State_machine
You should also go to your technical library and check out "The Art of Electronics" by Horowitz and Hill. Switch debouncing is covered in section 8.16 and synchronizer circuits are covered in section 8.19 (those section numbers are from my 1st edition copy -- the latest edition may have slightly different numbering).
BTW, I should clarify one thing. The interface to the buttons is the asynchronous part of your design. Once the buttons are debounced and those signals synchronized to the system clock, the state machine that you will design is synchronous.
the tip we received from the lecturer is priority encoder for the first stage then use a flip flop then led drivers these will help us design the circuit
so far we have covered binary, k maps, truth table, basic gates, flip flop, and decoders the rest we have to research
I cannot relate what we have covered so far to this design
If i get a clear picture in my head i will be able to do it
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
