Help elastic collistion, cons of momentum problem
  • Thread starter Thread starter nchin
    Elastic Momentum
In a perfectly elastic collision problem, block 1 with a speed of 10 m/s collides with block 2, which has twice its mass and a speed of 5 m/s. The equation for conservation of momentum is applied, leading to the relationship v1 + 2v2 = 20. The reason for multiplying v2 by two is due to block 2's greater mass, which affects the momentum calculation. The mass terms cancel out in the equation because they are proportional, simplifying the analysis. Understanding these steps is crucial for solving elastic collision problems effectively.
nchin
Block 1 moves with speed of 10m/s to right. It hits block 2 which has twice the mass of block 1 and speed of 5m/s to right. compute the magnitude and direction of block 1 for a perfectly elastic collision.
solution:
u1 = 10m/s
u2 = 5m/s
m1v1 + m2v2 = m1u1 + m2u2 ---->
v1 + 2v2 = u1 + 2u2
...= 10 + 2(5) = 20
(1) v1 + 2v2 = 20
why did u2 and v2 get multiplied by two and why did the m cross out?
Are you saying you've just copied these steps from somewhere else and don't know the logic behind them? If those steps were your own work, surely you know why you made them.
