HELP - Energy of a rolling sphere (no radius?)
The discussion revolves around calculating the total energy of a solid sphere rolling without slipping and determining its vertical height on an incline. The sphere has a mass of 0.602 kg and a translational speed of 5.18 m/s, with an incline angle of 34 degrees. Participants clarify that total energy includes both translational and rotational kinetic energy, as well as potential energy, despite not having a specific radius. The relationship between translational speed and angular speed is emphasized to express kinetic energy without needing the radius. Ultimately, the correct approach involves equating initial and final energy states to solve for height.
BlueSkyy
HELP - Energy of a rolling sphere (no radius??)
A solid sphere of mass 0.602 kg rolls without slipping along a horizontal surface with a translational speed of 5.18 m/s. It comes to an incline that makes an angle of 34degrees with the horizontal surface. Neglecting energy losses due to friction,
(a) what is the total energy of the rolling sphere?
(b) to what vertical height above the horizontal surface does the sphere rise on the incline?
KE = 1/2 m (v^2) + 1/2 I (w^2) where I = 2/5 m (r^2)
PE = mgh
I'm not given a radius so I can't use the KE equation...where do I go from here?
Once I have a radius it will be much easier to solve the problem...
Just call the radius "R" and keep going. :wink:
i kept "r" as a variable and came up with:
8.0766 + 0.1204 (r^2) (w^2)
but the problem asks for a specific number ( _____ J) so I can't keep the variable "r" there...
also, when they say total energy, do they mean total KE, since the ball is still in motion? I'm trying to use PE to solve for the height once I have KE solved...
When a sphere rolls without slipping, what's the relationship between the translational speed (v) and the angular speed (w)? (Express the full KE in terms of v and you won't see an "r".)
Total energy means include everything: translational KE, rotational KE, and PE. (When it's on the horizontal surface, I would just call that level PE = 0.)
AH! I forgot!
KE(rotational) = B 1/2 m (v^2) where B = 2/5
Thank you, I figured it out now~
E initial = E final
K initial translational + K initial rotational + PE initial = Same except final
is this what you mean? then solve for h on the final side?
Whome said:
E initial = E final
That's right.
Thank you.
