Help finding potential energy of spring.
The discussion revolves around a scenario involving two blocks compressing a spring and then being released on a frictionless surface. Block A has a mass of 1.00 kg and Block B has a mass of 3.00 kg, with Block B reaching a speed of 1.10 m/s after release. The final speed of Block A is calculated to be 3.30 m/s. Participants are trying to determine the potential energy stored in the compressed spring, with an initial kinetic energy calculation of 9.075 being questioned for accuracy. The conversation emphasizes the need for correct calculations to find the potential energy of the spring.
jgibbon2
Block A has mass 1.00 kg, and block B has mass 3.00 kg. The blocks are forced together, compressing a spring between them; then the system is released from rest on a level, frictionless surface. The spring, which has negligible mass, is not fastened to either block and drops to the surface after it has expanded. Block B acquires a speed of 1.10 m/s.
a) What is the final speed of block A? Found this answer to be 3.30 m/s
b) How much potential energy was stored in the compressed spring?
- how do you find this answer?? KEa+KEb=9.075 ... not right
check again your math in the KE calculation.
