Help Calculate Rate of Electrical Heating for Sphere
  • Thread starter Thread starter brazil2200
    Calculation
A solid sphere with a diameter of 2.54 cm is subjected to an air stream at 30.48 m/s, 1 atm pressure, and 37.7°C, while being heated to maintain a surface temperature of 93.33°C. The discussion emphasizes the need for the original poster to show their work and relevant equations to receive assistance, as it is considered homework. The rate of electrical heating required is linked to the cooling effect of the air, which depends on temperature difference, flow rate, and air properties like heat capacity and conductivity. Participants stress that help is voluntary and not guaranteed within a specific timeframe. Overall, the thread highlights the importance of demonstrating understanding and effort in problem-solving.
brazil2200
Please can anyone help me to resolve this problem:
a solid sphere 2.54 cm in diameter is placed in an otherwise undisturbed air stream, which approaches at a velocity of 30.48 m\s, a pressure of 1 atm. and a temperature of 37.7 oC. The sphere surface is maintained at 93.33oC. by mean of an embedded electric heating coil.what must be the rate of electrical heating in Watt to maintain the stated conditions
Thank you in advaned for your help.
L & G,
I still waiting for somebody to help me to solve the above problem.
Hopefully somebody will help me soon.
Thanks
brazil2200 said:
L & G,
Thanks
It is inappropriate to "bump" your thread in this way. First of all, it's homework/coursework, and you have shown zero of your own work. You MUST show your work before we can be of help. I've moved your thread to a Homework Help forum from the general technical forum where you originally posted.
Second, the help you get here at the PF is all volunteer help, and it is inappropriate to expect us to help you in some minimum time frame.
So, post your work on this problem, and show us what the relevant equations are. We may be able to answer specific questions or offer tutorial help at that point.
I don't know how to do it so I'll just try to get you thinking, Brazil.
The rate of heating will be related to the rate at which the sphere is cooled by the flowing air. Since you were given this question, you must know something about that and I will be most interested in what you can tell me about it! I suppose the rate of cooling depends on the temperature difference and the flow rate - but I would think also on some characteristics of air such as heat capacity and conductivity.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
