Help making IR Transmitter and receiver
An amateur modeler is seeking assistance in creating an IR transmitter and receiver system for a computer-controlled model car and roadway. They have successfully integrated a motor but are struggling to find suitable small batteries and require guidance on connecting the system to a microprocessor for controlling speed and lights. There is a discussion about the advantages of using infrared over radio frequency, with the modeler's preference for IR due to its reduced interference in an exhibition setting. The modeler requests specific advice on components and circuitry for their project. Overall, the focus is on developing a reliable control system for a 1:87 scale model.
Discript
Hi everyone
I am an amateur modeler and am very interested in physics and am trying to
to make a model car/roadway that can move and be controlled by a computer.
I have managed to placing a motor in the models, but have not found battery's which are small enough and can run it. So what i need Help with is this, I need some help and some advice on how to make the IR transmitters and receivers for the models, how to make the models work with a microprocessor and where i could get some and most of all how this can all go to a computer and be able to control the: speeds and lights on all cars and lorrys. Also any help with what motors that i should get that are very small and us little power.
Thx in advance and any help greatly appreciated.
Discript
well you could probably take radio control systems, that would at least overcome all the encoding and decoding processes. Just replace the Rf transmitter and receiver with infra red TX and RX modules.
But why use IR when RF will give better coverage with less drop out of signal ?
Dave
Hi davenn
I am working in 1:87 scale on a model, so there arent meany RC Cars for this scale. IF can not be interfered with as much as radio signals, and as i intend to exhibit this model i don't want radio signals Stopping the show. I was planing on putting IR transmitters around the board to give overall coverage.
Could you ma-by explain a bit more, i am a total amateur at electronics (i know a bit about circuits and stuff but need help with what components to get and such)
Thx allot
Discript
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
