- #36
TD
- 1,021
If you know A, a and c, you can use the law of sines:
[tex]\frac{{\sin A}}{a} = \frac{{\sin B}}{b} = \frac{{\sin C}}{c}[/tex]
An asymptote is a line that a curve approaches but never touches. This means that as the curve gets closer and closer to the line, it will never actually intersect with it.
To find the equation of a normal line, you first need to find the slope of the tangent line at the point of interest. Then, take the negative reciprocal of that slope to find the slope of the normal line. Finally, use the point-slope form of a line to find the equation of the normal line.
The average rate of change is the average rate at which a quantity changes over a specific interval. It is calculated by finding the difference between the final and initial values of the quantity and dividing by the change in time or x-values.
The vertical asymptote of a function is a vertical line on the graph where the function approaches infinity or negative infinity. To find the vertical asymptote, set the denominator of the function equal to zero and solve for the x-value. This will give you the equation of the vertical asymptote.
A horizontal asymptote is a horizontal line on the graph where the function approaches a specific value (usually zero) as x approaches infinity or negative infinity. A vertical asymptote, on the other hand, is a vertical line where the function approaches infinity or negative infinity as x approaches a specific value. In other words, a horizontal asymptote is a limit of the function as x goes to infinity, while a vertical asymptote is a limit of the function as x approaches a specific value.
