Can a 2KW Generator Handle a 5000 RPM, 27HP Engine for Tuning?
A 2KW generator is insufficient for a 27HP engine, as it only provides about 2.7HP, far below the required 20KW for proper operation. The power rating of generators typically refers to electrical output, and operating a generator beyond its rated RPM can lead to catastrophic failure due to centrifugal forces. Using a gear arrangement to increase RPM may exceed the generator's design limits, risking damage. It is crucial to select a generator that can handle the engine's power output and RPM requirements safely. For tuning a 5000 RPM, 27HP engine, a generator rated for at least 20KW is necessary.
srikanth977
We have a single cylinder 500 cc petrol bike engine. It's maximum power output is 27bhp( max) and the max rpm of the engine is 5000 rpm. We need to tune the engine to MAP it accordingly. We are thinking to use a generator to convert the mechanical power into electrical power.
I need help on the generator :
The generator available in the market are as
Output voltage: 230 v single phase
Power : 2kw ( I need help on this parameter)
Max rpm : 1500 to 3000(very rare)
My doubts are:
1) The power rating given is mechanical or electrical. Also is it the maximum or the minimum power.
2) Also we are using the 1500rpm generator, to get the 5000rpm equivalent we are using a 3:1 or 4:1 gear arrangement. So if My engine gives some output which is above the rated rpm of the generator then will the generator get damaged? IF yes then suggest the proper one. IF no then at what power the motor will stop running??
Please help, I need it for my collegiate project.
One HP = 746 Watts.
2KW / 746 == 2000/746 == 2.7HP. Oops! Ten times too small.
Lets see what wattage is needed for that 27HP engine.
27 x 746 = 20 142W, or a 20KW generator.
Running a generator much faster than its design speed has the danger of forcing the wires on the rotor to fly off due to centrifugal force. This pretty much destroys the generator and sometimes anything near it if it flys to pieces.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
