What is the angle between two component vectors with magnitudes 8 and 10?
  • Thread starter Thread starter findlayxc
    Vector
To find the angle between two component vectors with magnitudes of 8 and 10, the cosine rule can be applied. The formula used is c² = a² + b² - 2ab*cos(θ), where c is the resultant vector magnitude. By substituting the values, the angle θ can be calculated. The discussion highlights the need for clear formulas to compute the angle and resultant magnitudes. Ultimately, the solution was found elsewhere, indicating the urgency of the query.
findlayxc
Two component vectors with magnitude of 8 and resultant magnitude of 10. What must be the angle between the two component vectors?
I really don't know where to start on this. Any help would be greatly appreiated!
P.S. need by tomorrow!
Do you have any formulas to compute magnitude of the component vectors and the resultant magnitude?
found the answer somewhere else, thanks any way.
