Help transposing formula please :-)
  • Thread starter Thread starter ashisstuck
    Formula
ashisstuck
Could anyone please help me transpose the following formula:
Need to transpose so V= subject
Need to transpose so Z = subject
Hello ashisstuck,
Welcome to Physics Forums.
How would you go about solving the problems? Give it a try, and show us your work. :smile:
