Help with a linear algebra problem
kurosaki69
i need help with a linear equation problem. I started the problem and after a few steps i checked the problem in the solution manual and there seem to be a typo in the text so i wanted to have someone check my work if i was doing it correctly. if i made a mistake can someone please correct me and tell me what i did wrong.
matrix[(1,1,1), (1,1,0), (1,0,0)]
The solution in the manual had the same steps as below only the matrix was different it
was matrix [(1,1,0), (0,0,-1), (0,-1,-1)].
so i first i did R2 \rightarrow R2 - R1.
Then i did R3\rightarrowR3-1.
so my new matrix was [(1,1,1), (0,0,-1), (0,-1,-1)].
You're good so far, keep going.
so is my matrix correct and there is a typo in the book?
Yes, bc R1 should not change.
thanks a lot now i know the book has a few typos because i have encountered a few
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
