Help with AC Circuit containing a motor
The discussion revolves around an AC circuit problem involving a motor modeled as an inductor in series with a resistor. The motor is connected to a 230V RMS source at 50Hz, and participants are tasked with finding the motor's impedance, RMS current, and the relationship between resistance and inductance when a capacitor is added in parallel to reduce current.
  • Mixed
  • Participants explore the calculation of motor impedance and RMS current, questioning the use of peak versus RMS values in their calculations. There is discussion about the relationship between voltage, current, resistance, and inductance, particularly in the context of phasor notation.
Some participants have provided guidance on the use of phasor notation and the implications of using RMS values for calculations. There is ongoing exploration of the effects of adding a capacitor in parallel and how to combine impedances in such configurations. Multiple interpretations of the problem are being discussed, particularly regarding the values and units of capacitance.
Participants express confusion over the large capacitance value given in the problem, suggesting it may be a misinterpretation of units. There are also discussions about the implications of using different forms of voltage (peak vs. RMS) in calculations.
docsxp
Hello, this is not a homework question, but is a past year exam question which I'm stumped at. Any help will be appreciated.
1. Homework Statement
We're designing a current reduction system for an AC motor which is modeled as an inductor ##L##in series with a resistor ##R##. This motor is connected to 230##V_{rms}## at ##50hz##. An RMS meter is used to measure the current the motor takes. We need to find:
(1) Motor Impedance
(2) RMS current is measured as 15A. Voltage is ##v_a cos(\omega t)## and current is ##i_a cos(\omega t + \theta)##. Write down ##\omega##, ##v_a## and ##i_a##.
(3) Voltage is now ##v_a e^{j\omega t}##, write down current and hence obtain an equation that relates ##R## and ##L##.
(4) A variable capacitor is added in parallel that reduces current to a minimum of 12A when C = 0.1F. Write down the total impedance and find L.
##V=IZ##
##Z_t = R + X_l##
(1) ##Z = R + j\omega L##
(2)
##i_{peak} = \sqrt 2 \times 15 = 21.21 A##
##v_{peak} = \sqrt 2 \times 230 = 325.269 V##
##\omega = 2\times \pi \times 50hz##
(3) This is the part that I don't really get
Using ##V=IZ## we have
##i(t) = \frac{v_a}{\sqrt{R^2 + (j\omega L)^2}} cos(\omega t + \theta)## which I think can also be written as ##\frac{v_a}{\sqrt{R^2 + (j\omega L)^2}} e^{j\omega t + \theta}##
where ##\theta## would be ##tan^{-1} \frac{R}{\omega L}##
Is this the relationship they are looking for?
(4) Capacitor is added in parallel to existing impedance ##R+j \omega L##. Hence ##\frac{1}{Z} = \frac{1}{R + j\omega L} + j\omega C##
This is as far as I've gotten. Could someone guide me along please? Thank you.
Hi docsxp, Welcome to Physics Forums.
(1) Motor Impedance
Can you verify the value of that capacitance? 0.1F seems awfully large to place across a 230V mains. I'd expect it to pass a current of several thousand amperes! I suspect that the units are not Farads but perhaps milli-Farads (mF).
##V=IZ##
##Z_t = R + X_l##
(2)
I think that by expressing the voltage as ##v_a e^{j\omega t}## they mean to treat the voltage as a phasor (although I don't know why they chose to use the peak value rather than the RMS value).
In that case you can write ##I = \frac{v_a}{Z} = \frac{v_a}{R + j \omega L}##. Then taking magnitudes,
$$I_a = \frac{v_a}{\sqrt{R^2 + \omega^2 L^2}}$$
You can define a quantity ##X_o = \frac{v_a}{I_a}## (it'll come in handy later) and then write an expression relating R and L to it. Note that when you take the magnitude of the impedance you don't include the "j" in the imaginary term.
You can proceed as before and write an expression for the magnitude of the current phasor with the capacitor in play. Then rearrange as before to find the magnitude of ##E/I## (you have both for the second case: 230 V and 12 A RMS. Use peak if you wish). Define ##X_1 = \frac{v_a}{I_1}## where ##I_1## is your "new" current of 12 A. You should find that you can make use of the ##X_o## expression defined above to simplify things a bit and eliminate the R variable.
When you use ##|Z| e^{j\Phi}## notation do you not use ##V_{peak}##? Do you still use ##V_{rms}##?
gneill said:
You can define a quantity Xo=vaIaX_o = \frac{v_a}{I_a} (it'll come in handy later) and then write an expression relating R and L to it
So I attempted the question again and I'm still confused. When you say that I have to use ##v_a## do you mean the magnitude or do I have to treat it as a phasor? If we're focusing on magnitude then,
##i_a = \frac{v_a}{\sqrt{R^2 + (\omega L)^2}}##
##21.21 = \frac{325.269}{\sqrt{R^2 + (\omega L)^2}}##
And for the capacitor added, the overall impedance of the circuit, in terms of magnitude becomes ##|Z| = \sqrt{R^2 + (\frac{1}{\omega C} - \omega L)^2}##
Am I correct? Because the phasors for capacitors and inductors point in the opposite directions.
When we define ##X_0## do we use phasor notation?
When working with AC phasors the usual convention is to use the RMS values for AC voltage and current.
When RMS values are used, calculations of power (I*V) are straight forward.
When dealing with phasor values for calculation you use the magnitudes of the phasors along with their phase angles. Here you have measured values of current using an RMS current meter, so only the magnitudes are available to you.
Your formula for the overall impedance magnitude is not correct. Your formula would apply if the capacitor was in series with the R and L, but the capacitor in this case is connected in parallel with the RL branch. How do impedances in parallel combine?
The given values of voltage and current are phasor magnitudes. So ##X_o = 230 V / 15 A## would yield the magnitude of the impedance, that is, ##X_o = \sqrt{R^2 + \omega^2 L^2}##.
Like resistors in parallel. ##Z = \frac{1}{\frac{1}{j\omega L} + j\omega C}## But this will give rise to a very complex impedance.
Unless we leave it in ##\frac{1}{Z}## form.
I will try again with the corrected formula.
gneill, thanks for sticking with me for this long. Anyway I did the question again.
Using the combined impedance ##Z = \frac{1}{\frac{1}{j\omega L} + j\omega C}## we can actually calculate after simplification. However this system will be most efficient when there is no complex reactance, that is to say, in the phasor diagram I want to achieve a phasor lying entirely in real. The resistor here already is in the real, but the inductor is introducing complex reactance.
Hence I did ##\frac{1}{j\omega C} = -j\omega L## Because I want Im(Z) = 0
##\frac{1}{\omega C} = \omega L##
##L = 0.000101H##
Is this the correct answer?
No that doesn't work. You'll find that the real part of the impedance is influenced by the complex parts of the separate impedances and vice versa. Your impedance is given by:
$$ Z = \frac{1}{\frac{1}{R + j\omega L} + j\omega C} $$
Simplify it and take the magnitude. Note that the magnitude of this impedance will be equal to V/I for the 12 Amp case. Yes, it's a bit of a math grind...
You should see an opportunity to substitute in the Xo that was defined earlier, and R can be replaced using the same expression.
  • · Replies 21 ·
  • · Replies 20 ·
