Help with basic multivariable problem.
  • Thread starter Thread starter Vampire
    Multivariable
Vampire
Help with basic multivariable problem. [SOLVED]
Two surfaces intersect at a space curve C.
The two surfaces are 4y2 + 9z2 = 36 and x = 2y2 - 3z2
Find a vector parametrization for C. (r(t) = ( f(t) , g(t) , h(t) )
Find a set of values for the parameter t over which C is traced once.
None needed.
I've solved for a vector curve r(t) = ( t , \sqrt{3t/10+36/10}, \sqrt{2t/15-36/15})
I used x=t and solved the rest, but I'm not sure that it even correct. Additionally, I have no idea how I will find bounds for exactly one trace of C.
hi vampire, your paramterisation may not help as i don't think it traces teh whole curve, only a piece of it
have a think about your two sufaces, maybe try drawing some pieces along the axis planes in 3D...
The first equation represents a elliptic cylinder along the axis, the 2nd is harder to draw & looks like some kind of saddle type thing...
However its likely the 2nd surface cuts completely through the cylinder... giving a distorted ellipse over which C will retrace itself
With this mind... an idea could be to first try and parameterise z & y in terms of the projected ellipse on the y-z plane.
Choose cylindrical coordinates, with cylinder along the x axis, then z & y should be easy to parameterise in term of the angle. This should solve the first equation, use your 2nd to get x.
Not 100% it will work, but worth a crack...
Thank you for your help! Looking at it facing the y-z plane helped me solve it; thank you, lanedance.
I've solved it. I parametrized the elliptical cylinder using trigonometric functions:
z= 2sin(t) y= 3cos(t) and solved for x. x= 18cos^2(t) - 12sin^2(t)
t (0,2\pi)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
