Help with Conductors in Electrostatic Equilibrium
Two identical conducting spheres connected by a wire are charged, leading to a uniform surface charge distribution. A charge of 63.0 µC on one sphere results in equal charge distribution, with each sphere effectively having 31.5 µC after reaching equilibrium. The tension in the wire is influenced by the electrostatic force between the spheres, calculated using Coulomb's law. The initial confusion stemmed from incorrectly using the total charge instead of the charge per sphere. The problem was resolved by correctly applying the charge values.
ktobrien
Can someone please help me with this problem. I don't even know where to begin after drawing the picture.
Two identical conducting spheres each having a radius of 0.500 cm are connected by a light 1.80 m long conducting wire. A charge of 63.0 µC is placed on one of the conductors. Assume the surface distribution of charge on each sphere is uniform. Determine the tension in the wire.
Try to imagine what would happen as soon as you charge one of the conductors...
After reaching steady state, imagine the cause that would cause a "tension" on the wire...
What kind of a force is acting on the wire, and why?...Then the mechanics of the problem is really easy because you know the analytical formula to write the force between those two conductors, right?
Is F = ke*((q1*q2)/r2) the force equation you are talking about?
Never mind. I figured it out. I thought that was the equation I needed to use but I wasn't getting the right answer. The reason was because I was using the 63e-6 C as the charge of both spheres. I figured out that I was suppose to half that and use 3.15e-5 C as the charge of each sphere. Thanks for the help though.
Yes, that's correct. Good to hear that you've done it.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
