Help with conservation of kinetic energy and momentum
The discussion revolves around solving a physics problem involving a head-on elastic collision between an alpha particle and a gold nucleus. The equations for conservation of momentum and kinetic energy are set up, but the user encounters difficulties in obtaining consistent final velocities for both particles. They express confusion about the substitution process and the values derived for the final velocities. Other participants affirm that the approach is correct and encourage sharing specific numerical results for further assistance. The conversation emphasizes the importance of careful calculations and substitutions in solving collision problems.
skyze
Alpha particle mass - 4amu
velocity alpha particle - 3.0x10^5m/s
197Au Nucleus mass - 197amu
Head-on elastic collision. Find the final velocity of both the particles
Kinetic Energy conserved:
1/2m1v1i = 1/2m1v1f + 1/2m2v2f
Momentum Conserved:
m1v1i = m1v1f + m2v2f
For Momentum:
4 x (3 x 10^5) = 4V1f + 197v2f
3 x 10^5 = V1f + 49.25v2f
V1f = 3 x 10^5 - 49.25v2f
For Kinetic Energy
4 x (3.0 x 10^5)2 = 4V1f2 + 197v2f2
3.6 x 1011 = 4V1f + 197v2f
9 x 1010 = V1f + 49.25v2f
Subbing in one for the other
9x 1010 = (300,000 - 49.25v2f)2 + 49.25v2f
The v2f and V1f values I get doesn't work out
Thanks in advance for your help.
skyze said:
For Momentum:
V1f = 3 x 10^5 - 49.25v2fFor Kinetic Energy
Subbing in one for the other 9x 1010 = (300,000 - 49.25v2f)2 + 49.25v2f
That last v2f is really v2f2, right?
What values do you get? It looks like the right approach.
p.s. Welcome to Physics Forums!
