Help with contravarient vector transformation
fys iks!
Let A = <2,1> be a vector with contravarient components at a point P with coordinants u1 = 1 , u2=1. Find the components a-1,a-2 (-1 and -2 are upstairs) of this vector with respect to the coordinates u-1 = sqrt((u1)^2 + (u2)^2) and u-2 = arctan(u2/u1).
V^m(y) = (dy^m/dx^n) * V (x)^n
I got the second component to be -1/2 which is correct but for the first component i keep getting 2/2^(1/2) but the answer is 3/2^(1/2).
The derivative of u-1 wrt u1 is:
1/2 [ (u1)^2 + (u2)^2) ]^(-1/2) * (2*u1)
then when i plug in u1=1 and u2 = 1 you get 1/(2^(1/2)). Then i multiply that by the a1 component 2 and this is how i got my answer.
Can anyone see where i went wrong?
Remember that there is an implied summation over terms for u1 and u2 so that I think you are missing a term for u-1 with respect to u2.
If i sum over the terms then multiply by 2 i get 4/(2^(1/2)).
but i get the 3/2^(1/2) if i multiply the first term by the 2 then sum then second term.
but i don't know why you would do it this way since it breaks the order of operations.
also i didnt do a summation when i did the second component and i got the right answer.
I know that there should be a summation, but I am just not sure where/ when it should occurs
Thanks
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
