Calculating Electric Force with Coulomb's Law: Glass and Rubber Ball Example
In summary, Coulomb's Law is a fundamental law in physics that describes the relationship between two charged particles. The force between two charged particles can be calculated using the equation F = (k * q<sub>1</sub> * q<sub>2</sub>)/r<sup>2</sup>, where F is the force, k is the Coulomb's constant, q<sub>1</sub> and q<sub>2</sub> are the charges of the particles, and r is the distance between them. The unit of measurement for charge in Coulomb's Law is Coulomb (C), and it can be used for both positive and negative charges. Coulomb's constant (k) is a
gotpink74
49
What is the electric force between a glass ball that has +2.8 µC of charge and a rubber ball that has -4.8 µC of charge when they are separated by a distance of 4.5 cm?
2. Homework Equations
F=k*Q1*Q2/r^2
3. The Attempt at a Solution
-59.6507
-8.8888888.889
4.4380e12
i got -59.7333 but it is wrong HELP please
FAQ: Calculating Electric Force with Coulomb's Law: Glass and Rubber Ball Example
1. What is Coulomb's Law?
Coulomb's Law is a fundamental law in physics that describes the relationship between two charged particles. It states that the force between two charged particles is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
2. How do you calculate the force using Coulomb's Law?
The force between two charged particles can be calculated using the equation F = (k * q1 * q2)/r2, where F is the force, k is the Coulomb's constant, q1 and q2 are the charges of the particles, and r is the distance between them.
3. What is the unit of measurement for charge in Coulomb's Law?
The unit of measurement for charge in Coulomb's Law is Coulomb (C). It is named after the French physicist Charles-Augustin de Coulomb, who first described the law in the 18th century.
4. Can Coulomb's Law be used for both positive and negative charges?
Yes, Coulomb's Law can be used for both positive and negative charges. The force between two charges of the same sign will be repulsive, while the force between two charges of opposite signs will be attractive.
5. What is the significance of Coulomb's constant in the equation for Coulomb's Law?
Coulomb's constant (k) is a proportionality constant that is used to calculate the force between two charged particles. Its value is approximately 8.99 x 109 N * m2/C2. It is important because it determines the strength of the force between two charges.
