Help With Electromagnet and Air Cores
11 replies · 3K views
copperRobot
hello i need some help,
i know very little about EM. i would greatly appreciate any advise u can lend me.
i need to make an electromagnet but i am wondering how strong air cores can be? will an air core be able to work on and off continuously for hours at a very high rate of speed, it doesn't have to pull up a heavy load the piston it moves is quite light..
also to put this in prospective its a very small magnet moving a very small piece of metal very fast on/off for hours.. i do have a facility to make coils, i just need some advise on which kind..
Now, I am no expert in magnetics, I just join in. My understanding is the heat generated in a transformer or electromagnet is mostly from the eddy current in the conducting material of the core. If you have an air core, there is no eddy current and there should be no heating up in the air core. Heat is mainly from the power loss due to resistance in the winding.
Again, I am not an expert.
thanks, that's good to know.. i don't want heat to become an issue. but I am more concerned with power and the ability to work for hours
Make a coil using the smallest film insulated wire you have.
Apply a low voltage to the coil. Use a 1 1/2 volt battery.
If the coil or the battery overheats, you need more turns on your coil or smaller wire. If the magnetic field is too weak and everything is OK temperature wise, use two batteries in series.
CAUTION: If you break the circuit, there will be a high voltage and you could get shocked.
If you want more precise instructions, you have to provide details of what you are trying to do.
very informative.. thank you.
but my real question is about the strenghts of a solid vs air core electromagnet. i would like to produce the same amount of power as an 8 layer coil (20 -24 gauge copper) 1 1/4" inch tall.. with a solid core.
can an air core coil make as much power as a solid? i control voltage with an adjustable power supply, so is that all that is required? layers and voltage?
an air core would reduce weight and that's exactly what i want.
a strong, light magnet.
thanks again guys.. all informaton welcome
im using a manual switch to engage the piston. as soon as the magnet pulls the piston, it is pulled away from an electrical contact point shuting off the magnet. A spring returns the piston and repeats the process.
I like the part about the piston becoming the core.. that could save space
also I am using a 1.5 amp power supply, it can be adjusted up to 15volts.. output= DC
An electromechanical vibrator. You'll need good quality silver points or they will soon burn away.
man i was trying to be secretive and u found me out.. hahah. but every time my girl uses it she gets shocked! haha..
but seriously thanks. that's good to know.. i figured on using brass or something. ill have to find some silver
but wait. I am going to look into the vibrator deal a bit.. haha. they probly do run on a magnet huh?..
no they dont..
is there an easy way to tell how long a battery will power a continuous EM? because they make some nice batteries, i just wonder if it could run for up to 8hrs.. 1.5 amps, 3-10 DC volts (give or take.. room to fine tune its speed) output.. I have an DC regulated power supply
i have thought of that.. they would be perfect if i can make em fit right. but silver contact points are pretty cheap, an I've been looking into that a bit
i wish i could show u a pic but I am trying to not give to much away before my patent..
if i could make an air coil the same strenght as a solid core id be happy and my machine would be lighter ..
Its good to be able to bounce ideas off u guys tho
i really appreciate it.. thanks
