Where Do Sections 3.45 and 3.46 in Goldstein's 3rd Edition Originate?
  • Thread starter Thread starter ASmc2
Sections 3.45 and 3.46 in Goldstein's 3rd Edition originate from linearizing equation 3.34 about u = u0, leading to an equation for simple harmonic motion. The correct form of the equation is x'' + kx = 0, indicating an error in the initial derivation. The discussion highlights the importance of correctly differentiating equations to derive subsequent results. After addressing the mistakes, the participants confirm that equation 3.46 follows directly from the corrected form. The collaborative effort ultimately clarifies the derivation process for both equations.
ASmc2
This is a question to those who have the 3rd edition at their disposal. Where do 3.45 and 3.46 come from? I understood everything he said before that...
Start with equ. 3.34, an linearize it about ##u = u_0##. You will get an equation for simple harmonic motion, from which those two equations will follow.
I get an equation of the form x''+kx=c. where c is some constant, '' gives the second derivative with respect to theta, and x is u-u0.
You are on the right track, but you should have obtained ##x'' + kx = 0##. You made a mistake somewhere. Without seeing your work, I can't say what it was.
My work is attached.
That u0^3 and u0 terms bother me, as you can see.
The very first equation you have is incorrect. $$ {d \over du} V \left( \frac 1 u \right) \ne f(u) $$ Which is actually strange, because the third equation could only have been obtained if you had differentiated that correctly.
Likes 1 person
OK, I get that now, thanks. I got the correct equation now. Now to get (3.46).
3.46 should follow from what you got immediately: ##\ddot x + \beta^2 x = 0 ##.
Likes 1 person
Yes. Thanks for the help with 3.45
