Help with improper integral calculation
conniebear14
I'm supposed to find the integral of f(x) = (e^5x) / (1+(e^10x)) from negative infinity to 0. I know how to set up the integral as the limit as t approaches -∞ of ∫f(x) from t to 0, but I'm stuck on how to actually solve the integral. I've tried by parts and u-sub but I just can't seem to get it.
Any help would be appreciated, thanks in advance!
Well, if you set u=e^(5x), u^2=e^(10x).
Furthermore, you have:
du/dx=5u, that is dx=du/(5u)
Negative infinity in "x" goes to 0 in "u", whereas 0 in "x" goes to 1 in "u"
Your new integrand becomes 1/5*(1/(1+u^2)), which you should know how to integrate.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
