Help with Integral (Blended Cylinder)
  • Thread starter Thread starter minger
    Cylinder Integral
minger
This problem goes into a paper I’m writing. The exact problem deals with acoustic radiation from a plunging piston. Because of the CFD code I’m using, I can’t have a discontinuous grid at the piston boundary, so I must blend it. The results I’m getting at slightly off and I think it’s due to the effective volume of the displaced cylinder. Unfortunately the blending region that I’m using is making it tricky for me to integrate.
The volume of a cylinder can be give by:
<br /> V = \int_0^r \int_0^{2\pi} \int_0^H r\,dr<br />
I know the volume of the actual piston and only want the volume of the blending region, from r0 to r’. The blending region is given by the function:
<br /> f(r) =1.0-3u^2 + 2u^3<br />
Where:
<br /> u = \frac{r-r_0}{r_1-r_0}<br />
My final integral is then:
<br /> V = \int_0^{2\pi} \int_{r_0}^{r_1} \left( 1-3\left(\frac{r-r_0}{r_1-r_0}\right)^2 + 2\left(\frac{r-r_0}{r_1-r_0}\right)^3 \right)r\,dr<br />
Hope I typed that right.
Without the additional r on the far right, this is a simple substitution where:
<br /> dr = (r_1-r_0)du<br />
I eventually end up with:
<br /> V = \pi\left(r_1-r_0\right)<br />
However, with the additional r term, I cannot seem to figure out how to either use substitution or approach this. I would like to have the derivation of this for an appendix without simply putting:
http://integrals.wolfram.com/index.jsp?expr=%28+1+-+3*%28%28x-b1%29%2F%28b2-b1%29%29^2+%2B+2*%28%28x-b1%29%2F%28b2-b1%29%29^3+%29+*x&random=false
If I could get some validation on my integral and then point me in the right direction, I would greatly appreciate it.
p.s. This isn’t homework per say, so feel free to move it to the general math section if needed (figured I’d get more hits here).
OK, I think I got it figured out; I need to use both substitution and integration by parts. If the blending term is f(r ) and r is g(r ), then the volume is
<br /> V = 2\pi\left[ g(r )\int f(r ) – g&#039;(r )\iint f(r )\right]<br />
Letting
<br /> \begin{equation}<br /> \begin{split}<br /> r^* = r_2-r_1 \\<br /> u = \frac{r-r_1}{r_2-r_2}<br /> \end{split}<br /> \end{equation}<br />
Then the solution is:
<br /> V = 2\pi\left[ rr^*\left(u-u^3+\frac{1}{2}u^4\right)-r^*^2\left(\frac{1}{2}u^2-\frac{1}{4}u^4+\frac{1}{10}u^5\right)\right]<br />
In my case, my limits are from r1 to r2.
<br /> \begin{equation}<br /> \begin{split}<br /> r=r_2\rightarrow\,u=1 \\<br /> r=r_1\rightarrow\,u=0 <br /> \end{split}<br /> \end{equation}<br />
This means that most of the damn thing cancels at r1. Since the only r term is “alone” and linear I can just substitute the limits in there and reduce to:
<br /> V = 2\pi\left[\frac{13}{20}\left(r_2-r_1\right)^2\right]<br />
It should be right, thanks for anyone who considered the problem.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
