Help with integrating differential equation
teeeeee
Hi,
Could someone help me see how the solution of the equation \frac{1}{\mu} \frac{\partial p}{\partial z} = \frac{1}{\rho} \frac{\partial}{\partial \rho} (\rho \frac{\partial v}{\partial \rho})
is v = \frac{1}{4\mu} \frac{\partial p}{\partial z} \rho^{2} + C_{1}ln(\rho) +C_{2}
Thank you
teeeeee
Hi,
Could someone help me see how the solution of the equation \frac{1}{\mu} \frac{\partial p}{\partial z} = \frac{1}{\rho} \frac{\partial}{\partial \rho} (\rho \frac{\partial v}{\partial \rho}) is v = \frac{1}{4\mu} \frac{\partial p}{\partial z} \rho^{2} + C_{1}ln(\rho) +C_{2}
Thank you
teeeeee
Anyone? Please help
assume partial p over partial z to be some constant 'k'
expand the right side you now have a second order linear differential equation with a coeff
something like
(D^2 + D)v = (k/mu)*rho
remember rho is not a constant so find the transient solution
the sum of the steady state and transient solution is your answer
hope this helped
ps: i am lazy to use symbols
teeeeee said:
Hi,
Thank you
teeeeee
It isn't clear what variables depend on what, but you can check this. I will use subscripts for partials. Let's begin by calling
w = \frac{1}{\mu} \frac{\partial p}{\partial z}.
So you have
\rho w = (\rho v_{\rho})_{\rho}. Integrate with respect to \rho:
\frac {\rho^2} 2 w + C =\rho v_{\rho},\ v_{\rho}=\frac {\rho} 2 w + \frac C {\rho}
Integrate again:
v =\frac {\rho^2} 2 w + C\ln \rho + D = \frac {\rho^2} 2\frac{1}{\mu} \frac{\partial p}{\partial z}+ C\ln \rho + D
You can check it. Something is off by a factor of 1/2.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
