Help with LTspice Measuring Input/Output Impedance
  • Thread starter Thread starter hayowazzup
    Ltspice
The discussion focuses on measuring the input and output impedance of a BJT circuit using LTspice, exploring various methods and considerations for accurate measurements. Participants discuss the implications of circuit configurations, component values, and analysis types, including AC and transient analysis.
  • Some participants suggest using a resistor in series with the input to measure input impedance, proposing values like 10K or 1K.
  • Others argue that the method of measuring output impedance involves placing a resistor across the output and comparing gains with and without the resistor.
  • A participant questions whether AC analysis with AC amplitude is necessary for these measurements and if the method applies to oscillators and op-amps.
  • Some participants mention the importance of considering reactive components, particularly capacitors, in the circuit when measuring voltages.
  • There are discussions about the effects of changing component values on input impedance, with varying results reported by different participants.
  • A participant introduces the idea of measuring input current through a capacitor as a method to determine input impedance.
  • Some participants share their experiences with different transistor models and configurations, noting how these affect impedance measurements.
  • There is a suggestion that achieving a specific voltage gain from a BJT circuit may require careful selection of resistor values and configurations.
  • One participant raises concerns about measuring impedances without considering circuit loading, suggesting that this could lead to inaccuracies.
Participants express a range of views on the methods for measuring impedance, with no clear consensus on the best approach. There are competing suggestions regarding component values and circuit configurations, and some participants report differing results based on their setups.
Limitations include the dependence on specific circuit configurations and component values, as well as the potential impact of reactive components on measurements. Some participants note that changing the circuit alters the problem being addressed.
This discussion may be useful for electronics enthusiasts, students learning about circuit analysis, and engineers interested in practical applications of LTspice for impedance measurement.
hayowazzup
Does anyone know how to measure the input and output impedance of a bjt circuit on Ltspice? eg. a circuit like this
You can if you have actual component values.
You just put a resistor in series with the input to get the input impedance.
Try 10 K. Then the input will be reduced according to the input impedance.
You could calculate it or keep changing the resistor until the voltage is halved.
If the two voltages are not in phase, you might need to consider reactive components.
This could happen in this circuit as you have a capacitor in the feedback line.
The output impedance can be estimated by putting a resistor across the output to ground. Measure the gain with and without this resistor.
A resistor that halves the output will be equal to the output impedance. It is usually something like the resistance of the collector resistor.
I just tried it on Ltspice but there's something I still dun understand ..does this have to be done in ac analysis with ac amplitude?
And also will this method also work on circuits such as oscillator,opamp etc?
You could use transient analysis. This would tell you if the output was getting distorted. Look for "simulate" then "edit simulation cmd" then "transient".
Use an oscillator set to 1000 Hz with 50 mV out and a stop time of 5 mS.
Just measure the peak to peak value of the sine waves and calculate the ratio of them.
I think the 10 K I suggested is probably too high for typical components. Try 1 K.
You could test the output impedance of opamps like that but testing the input Z would depend on the circuit. Adding resistors to the input may upset the operation of the opamp.
I suppose you could test the output impedance of oscillators by loading them with resistance although it may affect the oscillation.
So I guess by putting 1k in series then I could just measure the Vin p-p and use the voltage divider rule to solve for Rin?hmm I tried it but it doesn't seem to work.
Yes, I think you have done it wrongly.
You are measuring DC voltages, but there is a capacitor C1 in series with the input.
Just put a 1K in series with the capacitor (on the left of it) and measure the voltages on each side of the resistor.
I have tried it with voltage divider rule but when I put the Rin value back at the resistor it measures 0.64 of the voltage source, is that normal?
Could be.
Which resistor did you use as the series one? What were the values of the bias resistors and the capacitors.
I guess you measured voltage with respect to ground, did you?
If it was 64% getting to the capacitor, and 1000 ohms you could say the input impedance was 1000 * 64 / 36
This is actually the circuit I am working on
[PLAIN]http://img96.imageshack.us/img96/8237/bjt1.jpg
I've chosen the first two peaks to measure.
P-P voltage 2.58 - (-1.207) = 3.845mV
so 3.845 = (R/(1000+R) * 100 => R = 39.9875 Ohms
[PLAIN]http://img713.imageshack.us/img713/6051/bjt2.jpg
P-P voltage 28.12 - (-36.38) = 64.5mV
Maybe I should pick a larger capacitor value?
So, you have 64.5 mV on one side of the 1K resistor (to ground) and 3.845 mV on the other side (to ground). Is that right? I couldn't see where some of your figures were coming from.
If so, I make that about 63.3 ohms input impedance.
This happened because you changed the circuit. You now have a lot of signal current coming back from the output to the base and this makes the input impedance low.
You should try putting a large capacitor (10 uF) at the junction of R1 and R4, to ground. This should remove most of this feedback. This was the function of C3 in the previous circuit.
In your circuit, you changed the value of the series resistor. You need to take two readings: across the input signal and from the other side of the 1 K resistor to ground.
[PLAIN]http://dl.dropbox.com/u/4222062/input%20Z.PNG
So, from each of the points with a red arrow pointing at it, to ground
Note the capacitor added as well.
We RF engineers do things a little differently. We like to measure impedances with all the inputs and outputs terminated the way they will be when the circuit is operating. If we don't, the circuit will most likely oscillate. So for me, the first thing I notice is that there is no load in the circuit. If we measure the impedance this way, it may change when a load is connected. What is the expected load when the circuit is operating?
Nevertheless, if we are to measure the input impedance of the circuit as it is, it seems to me the most logical way to do it is to plot the AC voltage at the left of C1 divided by the AC current through C1. There are different ways of doing this and I'm not familiar with LTSpice, so you'll have to find the right commands.
You may be able to use Mag(V(n007))/Mag(I(C1)) or VM(V(n007))/IM(I(C1)) or RMS(V(n007))/RMS(I(C1)), or something similar.
The idea of measuring the input current is good and easily done with LT Spice.
It would be available just by left-clicking on the capacitor in the circuit diagram after a simulation has been run.
For example, I entered the circuit into PSPICE and not having a model for the BF199, I used the 2N2222. In order to get the output into the linear region I also had to change R2 to 390 K ohms. To begin with, I put a 1 meg resistor from C2 to ground. The input impedance was, using the method I suggested was about 10 K ohms. Then I reduced the resistor on C2 to 1k ohm and the input impedance dropped to about 31 ohms.
I tried that with a 2N2222 and got very different results. I had to use 400 K as the bias resistor, too.
Without the extra 1K resistor, the input impedance was 952 ohms. When it was added I got 1176 ohms. Not a lot of difference, but an increase.
I would expect this, too, because the extra resistor drops the total gain and hence the current feedback is reduced.
However, this is not the point of the exercise. The circuit should remain as it was originally proposed. If you change it, it is a different problem.
I substituted a 2N3646 which has a much lower current gain (only 86) and this allowed me to reduce the bias resistor to 100 K. The input impedance was then 303 ohms.
If you still have the model, could you try this again?
Yes, I made a mistake in my example. Now I'm getting 2.4K for both the 1K and the 1meg resistor.
thanks a lot for the replies above. I really appreciate it.
by the way, I have a question that's unrelated to the topic.
Is it possible to bias the bjt so that the output voltage can have a voltage gain of 20 (2V peak to peak AC) from a 100mV p-p signal ? I tried changing the resistors value so many times on ltspice but still couldn't get a linear 2V peak to peak ac at the output.
For exact voltage gains, you may need to look at op amps.
However, you can approximate the result like this:
[PLAIN]http://dl.dropbox.com/u/4222062/X20%20amp.PNG
The gain is roughly the ratio of R5 / R2. Because R5 is in parallel with the output resistance of the transistor, R5 has to be a bit bigger than this formula.
Having an emitter resistor improves the input impedance of the amplifier too. It is about 10 K as shown.
I have a textbook about transistors that talks about transistor gain. It says that current gain is limited to beta but voltage gain can be much greater than beta. What if failed to mention is that voltage gain greater than beta comes from impedance transformation and it is no more real than voltage gain with a transformer. The gain isn't real because you can't cascade two such stages and expect to that amount of gain squared, because the output to input impedance is mismatched. You can also get current gain greater than beta by transforming the output impedance to less than the input impedance.
Also amplifier gain doesn't have to be a unitless number. Tube gain was often given as current out over voltage in or mhos (ohms backwards, now called siemens) on the other hand a transistor amplifier that produces 1 volt output change for every 10 mA change in input, could be said to have a gain of 100 ohms.
If you cascade two of the amplifiers above, the input impedance of the second one becomes part of the load of the first. So, if it was 10 K in, the load on the first one would be about 3 K and the gain would drop to a bit less than 13.
The second stage would still have a gain of 20, though, so the total gain would be a fairly predictable 260.
It is a very real gain. It would produce 2.6 volts p-p from a low output microphone, for example.
You can get voltage gains greater than Beta. Beta is a current gain, not a voltage gain.
Signal current through a resistor produces a signal voltage of IR, just like Ohm's Law.
So the voltage produced depends on the resistance as well as the current.
While you could probably get a voltage gain of 260 with one 2N2222, much better bandwidth is available if you produce it in two or more stages.
Yes you can get voltage gains greater than beta just as with a transformer you can get voltage gains of greater than one. And yes beta is a current gain figure.
How does current gain translate into voltage gain? You can divide the input voltage by the input impedance to find the input current. Then multiply the input current by beta to find output current. Lastly multiply output current by output impedance to get output voltage. What voltage gain would you have if input and output impedances are equal? Of course voltage gain benefits if the output impedance is higher than the input impedance. However if two such stage are cascaded, the voltage gain due to a change in impedance is lost because of the mismatch between stages. My point is that any voltage gain due to an increase output impedance over input impedance is only useful for high impedance loads, and is not any different than voltage gain in a transformer. Such gain cannot be used in multistage amplifiers.
Can you show me an example of an amplifier with equal input and output impedances and a voltage gain greater than beta? If you look at the amplifier in terms of maximum power gain, things may be a little clearer.
In your example, I don't think you are claiming the beta of the transistor is less than 13 or even 20. The problem with claiming that a single amplifier stage has a gain of 260 (which I see no problem in doing) is that the next step is to add another identical stage and expect to get a total voltage gain of 67,600.
You have real gain if the power of the output is greater than the input. This is the case with most transistor amplifiers. You compare this to a transformer where the power out cannot be more than the input.
For example, you could follow a voltage gaining common emitter amplifier with an emitter follower.
You have high input impedance followed by a low output impedance. You could cascade these modules as much as you like or until the noise from the first stage is amplified enough to be objectionable.
Cascading stages is not the only reason to build an amplifier. You may want to drive a meter or a lamp or close a relay. You could drive a FET or the input of an oscilloscope or a frequency counter.
Exactly.
Correct, but the product of the voltage gains of the individual stages can never be greater than beta^n where n is the number of stages and the output impedance is equal to the input impedance.
True, but I would prefer to use a different term for voltage gain due only to impedance transformation. For instance the familiar 20*Log(Vout/Vin) does not apply in those cases and I don't think this is made clear in many EE classes.
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 21 ·
