Help with Magnetic Dipole Moment
The discussion centers on calculating the resultant magnetic dipole moment of a permanent magnet within a steel housing, with concerns about the effects of the housing on the magnetic moment. The user is utilizing COMSOL for numerical modeling but is confused by the unexpected increase in magnetic moment when the steel housing is added, contrary to expectations that it should decrease. Participants emphasize the importance of understanding the relationships between magnetization, magnetic induction, and the properties of ferromagnetic materials, noting that steel reroutes rather than absorbs magnetic flux. They suggest that the user consult with someone experienced in COMSOL to review the model and assumptions, as simulation intricacies can lead to errors. Accurate modeling of complex geometries versus simplified representations is also highlighted as a critical consideration.
Nash Engineer
Im looking to find the resultant magnetic moment of a permanent magnet inside of a steel housing. Some of the remnant flux density is absorbed by the magnet and the field is altered. I want to figure out the total magnetic dipole including the presence of the steel housing. I've been using Comsol but I am new to that program and I am unsure of how to work the formulas
Magnetic fields in the presence of iron are not readily soluble analytically, so numerical modeling is the right way to go. I don't understand what you mean by "how to work the formulas." Have you taken an advanced undergrad E&M class? You'll see how magnetization, magnetic induction and magnetic fields are related, and how a ferromagnetic material doesn't "absorb" flux but rather reroutes it (the relevant properties are permeability and reluctance). I'm not familiar with Comsol but would be surprised if it requires formulas--don't you mesh up your geometry and solve it with finite elements or some similar technique?
Well, I'm a mechanical engineer but this is part of a project I have to do. Yes I am just meshing it in comsol. I am then using the the software to calculate magnetization of the entire volume. What I am confused about is that when I have the permanent magnet alone I get the correct Magnetic moment, however when I add the steel housing around the Magnet I get higher Magnetic Moment which doesn't make sense. If I want to find the magnetic moment to simplify this assembly into its equivalent singular magnet to use in another more complex model I think I should expect the Magnetic moment to drop a little with the addition of the steel housing.
Can I expect the magnetic moment that's routed through the steel to take away from the effective magnetic moment in this case?
Agreed, moment shouldn't look bigger. Without knowing details of your problem, geometry, etc., it's impossible to know where you went wrong. Simulation codes can be tricky, especially regarding meshing and boundary conditions. The best approach would be to sit down with someone experienced in COMSOL who can review your model and assumptions. A couple of other questions they can address: How do you know that the dipole moment of the permanent magnet is "correct"? Why do you assume that your larger system will be accurately modeled if you replace a complex geometry by a simple dipole?
Sorry, this is not the sort of problem that I could diagnose over internet even if I were familiar with COMSOL.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
