Understanding Magnet Alignment: Answers to Common Questions | Homework Help
  • Thread starter Thread starter fredrogers3
    Magnets
The discussion focuses on understanding magnet alignment and the behavior of a suspended magnet in relation to an external magnetic field. The first question addresses which pole of the suspended magnet aligns with the external field produced by a second magnet. The second question explores the orientation of a compass needle in proximity to a magnet. The user expresses confusion about how to approach these questions, particularly regarding the interaction of the Earth's magnetic field and the influence of the second magnet. The conversation emphasizes the importance of visualizing magnetic field lines and applying the principle of superposition to determine the resulting orientations.
fredrogers3
I have found a picture of the diagram here:
http://imageshack.us/a/img850/3364/imageacm.jpg
The first question asks the following: Once the suspended magnet has aligned itself with the magnetic field, which of its poles points in the same direction as the external field produced by magnet 2?
The next question asks me to consider a compass placed near a magnet. The question asks "which way the north pole of the compass would point with respect to the center of the compass?"
See Below
I first drew the final arrangement of the suspended compass. Specifically, I drew the north pole of the suspended magnet "over" the south pole of the stationary magnet and vice versa. I also drew the magnetic field lines in as exiting north and entering the south pole of the magnet. With that in mind, I'm a bit confused as to how to approach the first question I have asked. With regard to my second question, is it simply asking me which way the needle of the compass points at that particular location?
Thanks
Think of the Earth's magnetic field caused by a huge bar magnet with its S pole near the geographic North pole. Sounds goofy but there it is.
What effect does the Earth's field by itself have on the swinging bar magnet orientation?
What effect does the second bar magnet, given its orientation, have on the swinging magnet?
Then use superposition to get your answer.
