Projectile Motion at the Top of a Hill: Angle and Height Calculation
The discussion revolves around calculating the angle and height of a projectile launched from a hill to hit a boat moving at a constant velocity. The projectile's initial velocity is 96.6 ft/s, and the boat travels 100 ft in 5 seconds, requiring the projectile to cover a total distance of 401 ft in the same timeframe. Participants suggest using vector components and parabolic trajectory equations to determine the angle and height of the hill. The importance of treating horizontal and vertical motions independently is emphasized, along with the need to find the intersection point of the projectile and boat paths. A tutorial on projectile motion is recommended for further understanding of the concepts involved.
the_d
***Help With PROJECTILE MOTION***
im giving a problem where i have to find the angle a projectile situated at the top of a will hit an boat wit constant velocity 20 ft/s 5 sec after starting at Vo = 96.6 ft/s and also how high the hill is above the water. The distance from the base of the hill to the boat is given to be 301 ft.
i found the distance the boat travels after 5 seconds to be 100 ft. now I am trying to calculate the Vx and Vy components of the projectile to get theta, any suggestions?? thanx
Draw a vector triangle and use cos and sine functions. youll see it.
i found the angle but how do i find the height of the hill?
Again, which are the equations of displacement? Use the height of the hill as an initial, let's say, y-position.
Can someone help me figure out the height of the hill for this problem, i am stuck...thanks
The projectile follows a parabolic trajectory, but it is starting at a higher elevation than it will end.
One simply finds the point at which the boat and projectile paths intersect at 5 seconds.
The boat travels 100 ft in 5 seconds, the project must travel (310 ft + 100 ft = 401 ft) in those same 5 seconds. Knowing the distance traveled and the time, what value can be calculated?
i figured that part out already but now i am having a hard time computing the height of the hill, I tried making a triangle out of the picture but i only have one side 301 and one angle 90 degrees, am i missing somrthing?
Well, if one has the equation of the parabolic trajectory, then one can determine the time from start to the peak of the trajectory, and from peak of trajectory to impact point. One can then subract the distance traveled from beginning to peak from the peak to impact and that gives the starting elevation.
So one has calculated the angle at the beginning?
Bear in mind, assuming no wind resistance, the horizontal velocity is constant.
Seems it would be a great idea to post a detailed tutorial on projectile motion, since it's such a frequent question.
What a smashing idea! Just marvellous
We'll see what we can do.
Meanwhile, Greg Bernhardt posted a tutorial on "Motion in 2 Dimensions"
https://www.physicsforums.com/showthread.php?t=95427
Page 11-15 (including worked example) covers projectile motion.
4. Problem-solving strategy for 2–D motion:
a) Select a coordinate system (typically Cartesian).
b) Resolve the initial velocity vector into x and y components.
c) Treat the horizontal motion and the vertical motion independently!
d) Horizontal motion has constant velocity. (Assuming wind resistance is neglected.
e) Vertical motion has constant acceleration (usually gravity).
Afterall, the parabolic trajectory can be described by pair of parametric equations x = x(t) and y = y(t), which describe the location or coordinates as functions of time.
http://archives.math.utk.edu/visual.calculus/0/parametric.6/index.html
http://colalg.math.csusb.edu/~devel/precalcdemo/param/src/param.html
http://www.math.hmc.edu/calculus/tutorials/parametric_eq/
