sophiecentaur
- 30,531
- 7,516
Presumable this is a European built beast so it would be expected to take single phase 220V. The blue and brown leads sort of confirm this (along with the stripey European Earth wires).
But I am now totally confused because the earlier pictures are not the same as the later pictures. The earlier picture shows a blue lead going to both halves and to the 0V teminal but the later picture shows grey wires (the same one? joining the 0V on one half to the 110V on the other. Have you changed something?
Is this all to do with making the equipment re-configurable for use with 110V in the US, I wonder? I don't see any advantage in that system compared with having a double length (220V) primary winding on one core with a 110V tap half way up.
But I really have a problem in seeing exactly how the two halves, connected in series, can work 'properly' when fed with 220V because the share of the 220V that each half gets will depend upon the secondary load that each half is presented with. Weird. Looking at the secondary connections, it seems that they are connected in parallel and that would, presumably present equal loads to the two halves which, in turn, would tend to balance up and cause the mid point (grey) to float 'half way in between' the live and neutral connections. It should not, presumably, be connected to any ground but just be allowed to float.
@Bassalisk it could be a good idea to try and draw a circuit diagram of the system but I appreciate that it could cause some brain ache if you aren't familiar with that exercise. I can't see where those yellow wires are going and I'm also confused about what happens to the purple (9V) wires too. Are they just joining the secondaries in parallel?
