Help with two electrical circuits please
The discussion revolves around two electrical circuits where the original poster seeks assistance in determining voltage, current, and power across resistors. The subject area is electrical circuits, specifically focusing on circuit analysis techniques.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the application of Kirchhoff's Current Law (KCL) and Kirchhoff's Voltage Law (KVL) to formulate equations for the circuits. There is uncertainty regarding the direction of currents at the nodes, with some participants suggesting that arbitrary choices for current directions can be made.
Guidance has been offered regarding the selection of current directions and the implications for voltage polarity across resistors. The conversation indicates that multiple interpretations of the circuit setup are being explored, and there is an emphasis on the self-correcting nature of the mathematical approach.
The original poster expresses a lack of clarity on how to initiate the analysis of the circuits, indicating potential constraints in their understanding of the foundational concepts involved.
diegovmtj
OP warned about not having an attempt at a solution
Hey, I am having problems with this. I need help with these 2 circuits I am basically lost and not sure how to start. I need to find voltage, current and potency on each resistance
help would be much appreciated, thank you
http://imgur.com/trm1On0
http://imgur.com/a/KD3zr
What have you tried?
i know that i have to use the KCL in each node, then use KVL to find the 4 equations so i can get the currents and voltages, the thing is that i don't know if the currents are going in or out of the nodes
It doesn't matter what you choose for the current directions, the math will "self correct" any bad choices so long as you stick to your choices while you write the equations. If a current direction was chosen incorrectly the result will be a negative value for that current, telling you that it flows in the direction opposite of your guess.
+1
Choose/define an arbitrary direction for +ve current in each loop and mark on the diagram.
Work out what that current means for the polarity of voltage drops across resistors and mark those on the diagram.
Write KVL equations based on those voltages.
Write KVC equations for the nodes (perhaps assume current going into a node is +ve).
Solve the simultaneous equations
If a current turns out to have a -ve value then it's going the opposite way to the arrow on your diagram.
