At what height does the boy lose contact with the ice?
In summary, the problem involves a boy sliding down a frictionless hemispherical ice mound. To find the height at which he loses contact with the ice, we can use Newton's Second Law and the Conservation of Energy. By setting up equations for the centripetal force and the conservation of energy, we can solve for the boy's speed at a given angle theta. Then, by setting the normal force equal to zero when the boy loses contact, we can solve for theta and ultimately determine the height at which the boy loses contact with the ice.
mikesown
"A boy is initially seated on the top of a hemispherical ice mound of radius R = 13.8m. He begins to slide down the ice, with a negligible initial speed. Approximate the ice as being frictionless. At what height does the boy loose contact with the ice?"
PE = mgh
KE = 1/2mv^2
PE + KE = constant
I have absolutely 0 clue what to do... to start, I equated PE and KE to get:
mgh = 1/2mv^2
gh = 1/2v^2
h = 1/2v^2/g
I do not think that's correct though... Any ideas on how to approach this?
You'll want to use two tools here, the first being Newton's Second Law. Using a centripetal coordinate system, how would you set up the F =ma equation? Second, friction is negligible, so you can use the Conservation of Energy to determine a height.
Think of it this way, if the boy moves a distance down the hill, he will have swept out an angle theta from his initial starting point. At this point, how would you construct Newton's Second Law? What two centripetal forces are acting on him?
If you look at his position at some angle theta from the top you should be able to compute the component of mg that is normal to the hemisphere. You should also be able to compute v as a function of theta and from that get the radial acceleration. If the normal component of mg drops below the value of the radial acceleration, he can't stay on the hemisphere.
Hmm, I'm still not completely understanding how to set up the problem. Here's what I'm understanding:
There are two forces acting on the person, the force of gravity(mg), and the centripetal force acting as he slides down.
I am still not understanding how to formalize this into mathematics. How can I describe his position as a function of theta?
If you measure angle from the bottom of the hemisphere, x=R*cos(theta), y=R*sin(theta). The v can be found by considering the change in y from the top of the sphere. I'm not sure what your question is exactly.
The two forces acting on him is 1) a component of the weight force (this is his centripetal force) and 2) the normal force. I would suggest drawing a diagram if you haven't. If we take centripetally outward to be positive, our equation will look similar to this:
[tex] \Sigma F_{centrip} = N - \frac{cos \theta}{W} = -\frac{mv^2}{r} [/tex]
Now you have two unknowns and one equation. Use the equation for the conservation of mechanical energy to get the boys speed at some angle theta, and plug it into the above equation. Then consider what force in the force equation must go to zero when the boy loses contact with the hill. This will allow you to solve for theta, which in turn will allow you to solve for the height.
1. What is "hemisphere sliding down"?
"Hemisphere sliding down" refers to a hypothetical scenario where one half of the Earth's surface slides down towards the other half due to a shift in the Earth's axis or other external forces.
2. Is hemisphere sliding down a real phenomenon?
No, this is purely a theoretical concept and there is no evidence or scientific explanation to support the idea of a hemisphere sliding down on Earth.
3. What would happen if a hemisphere actually slid down?
If such a scenario were to occur, it would result in catastrophic consequences such as massive earthquakes, tsunamis, and changes in climate and weather patterns. It would also disrupt the Earth's rotation and potentially alter its orbit.
4. Are there any real-world examples of hemisphere sliding down?
No, there are no known instances of a hemisphere sliding down on Earth. However, there have been cases of landslides and other natural disasters that have caused significant changes to the Earth's surface.
5. Could a hemisphere sliding down happen in the future?
Based on our current understanding of the Earth's structure and processes, it is highly unlikely that a hemisphere sliding down would happen in the future. The Earth's axis is relatively stable and any major shifts would require extremely powerful external forces.
