What frequencies are present in a spark and its resulting hertzian waves?
  • Thread starter Thread starter PH7SICS
    Harmonics Wave
A spark generated by a high voltage capacitor creates hertzian waves, similar to those produced by lightning. These waves exhibit a wide bandwidth due to the impulse nature of the spark, which includes a fundamental frequency and its harmonics. The medium through which these waves propagate affects their attenuation, leading to the emergence of resonant frequencies, such as Schumann resonances. The discussion highlights that all frequencies are present in the impulse response, but atmospheric conditions filter and absorb them differently. Ultimately, the nature of hertzian waves involves both fundamental wavelengths and their harmonic multiples.
PH7SICS
A high voltage capacitor is charged and then the two leads are shorted together generating a spark, simultaneously a nearby radio crackles. This shows us that when the spark was generated radio waves was also generated. These primitive radio waves are sometimes called hertzian waves. A bolt of lightning also generates hertzian waves.
My question is about the nature of the waves produced. When a bolt of lightning strikes the ground dose it produce a predominant frequency wave along with its harmonics?
Let me explain with an analogy, a stretched wire when plucked produces a fundamental pitch but simultaneously pitches are produced which are harmonic multiples of the fundamental pitch. If a stretched wire produced a fundamental pitch of 100hz then it will also produce pitches of 200, 300, 400hz etc
When a hertzian wave is produced dose it also have a fundamental wavelength along with harmonics which are multiples of the first?
A spark will act as an impulse, generating a wide bandwidth. The properties of the medium in which the waves propogate will attenuate some frequencies more than others, so the long-time behavior will result in the appearance of resonant frequencies (Schumann resonances, for example).
Here's a fun website- audio recordings of the "audio" portion of the EM spectrum during thunderstorms:
http://www-pw.physics.uiowa.edu/mcgreevy/
Thanks for the info Andy...it still leaves my question unanswered though:biggrin:
i think he did in the first line...
all frequencies are available in the impulse response...and generally are of the same magnitude...
the resonances (schumann) he described are the resulting peaks of atmospheric filtering...because of the size of the cavity namely height from land to top of atmosphere and space around the earth...the rest are absorbed more quickly...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
