How Does Relativity Affect Light Travel in Different Inertial Frames?
  • Thread starter Thread starter the_liong
    Genius Hi
the_liong
Hi all, pls help me solve the problem below,easy for you right? I very appreciate your help, thank.
Question:
A flash of light is sent out from a point x1 on the x-axis of an inertial frame S, and it is received at a point x2 = x1 + g. Consider another inertial frame, S´, moving with constant speed V = bc(c=light speed) along the x-axis; show that, in S´:
i) the separation between the point of emission and the point of reception of the light is g´ = g{(1 – b)/(1 + b)}^1/2
ii) the time interval between the emission and reception of the light is t´ = (g/c){(1 – b)/(1 + b)}^1/2.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
