Hi, the wikipedia article on fermium states that it is the last
Fermium is noted as the last element that can be synthesized through neutron bombardment, primarily due to the instability of heavier elements. Beyond fermium, atomic nuclei are less likely to absorb neutrons and instead may undergo fission or eject particles. The discussion highlights that while neutron bombardment leads to a single proton increase via beta decay, alpha particle absorption results in a two-proton increase, changing the element entirely. The short half-lives of heavy elements necessitate stable targets for synthesis, making the use of heavy ions more effective for creating elements beyond fermium. Overall, the synthesis of heavier elements relies on specific nuclear reactions and the stability of the resulting isotopes.
Jarwulf
Hi, the wikipedia article on fermium states that it is the last element that can be synthesized by neutron bombardment but decides not to explain why. Can anybody give a layman's explanation? Thanks.
Elements heavier than Uranium and Plutonium are created when neutrons are absorbed into the nucleus and then Beta Decay into a proton. This creates a new element since the number of protons differentiate the different elements. Past fermium, I'm guessing that the nucleus will no longer absorb a neutron and then beta decay. It most likely will fission or simply eject other particles as soon as the neutron is absorbed.
Yeah but what is the reason behind that? And why would you be able to do it instead with something like an alpha particle?
Absorbtion of an alpha particle immediately changes the atom to another element since you are adding 2 protons.
As to the why, I can't tell you. I'm not an expert on nuclear physics.
Primarily because of the short half-lives. You need a target that will sit still long enough. And neutron bombardment followed by beta decay only takes you one step up, Z -> Z + 1. Using alpha particles instead will take you two steps, but more realistically it's better to use heavy ions. To make Nobelium they used 13C ions. Rutherfordium it was 22Ne, Seaborgium it was 18O, and so on. The highest element named so far, Copernicium (at no = 112), was found using 70Zn on 208Pb.
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
