Higgs mass - Why is it a Gaussian distribution?
In summary, the spread in mass values seen in the plots of the decay channel H=>ZZ=>4 Muons is due to limitations in detector resolution. The invariant mass of the parent Higgs particle is determined by measuring the directions and energies of the outgoing leptons, leading to a spread in calculated mass values. The intrinsic width of the Standard Model Higgs is much smaller than the width observed in the plots, which is dominated by detector resolution. The Higgs would show a similar effect as the Z particle, but its predicted width of 4 MeV is too narrow to be directly observed at the LHC.
AlanKirby
Hi, so my question is along the lines of the following:
If I'm looking at the decay channel H=>ZZ=>4 Muons, why would the resultant distribution for the mass of the parent Higgs be a Gaussian?
Is it a case of the peak is the actual value of the Higgs at rest; those of greater mass are Higgs that are moving; those with smaller mass are 'off shell' Higgs particles?
Thank you kindly for any responses.
The spread in mass values you see in the plots comes from limitations in detector resolution. To determine the mass of the parent particle from its daughters, you need to measure the directions and energies of the outgoing leptons, and then determine the invariant mass of that system (in this case, four leptons). Those measurements are only so good, leading to a spread in calculated mass values.
The intrinsic width of the Standard Model Higgs is only 4 MeV, much smaller than the width you can read off the invariant mass plots.
Likes AlanKirby
The plotted mass values are always the invariant mass, which is the energy of the Higgs in its rest frame.
The experimental shape is dominated by detector resolution. If you take the Z, on the other hand, its shape is a Breit-Wigner function and comes from its finite lifetime (it can be a bit off-shell). The Higgs would show the same effect, but with a width of (predicted) about 4 MeV it is way too narrow to see it directly at the LHC.
Likes AlanKirby
Related to Higgs mass - Why is it a Gaussian distribution?
1. What is the Higgs mass?
The Higgs mass is the mass of the Higgs boson, a fundamental particle that is responsible for giving other particles their mass through the Higgs mechanism. It is a crucial component of the Standard Model of particle physics.
2. Why is the distribution of Higgs mass Gaussian?
The distribution of Higgs mass is Gaussian because it follows a normal distribution, which is a common pattern seen in natural phenomena. This means that the majority of Higgs bosons have a mass close to the average value, with fewer particles having masses that deviate significantly from this average.
3. How is the Higgs mass measured?
The Higgs mass is measured through experiments at particle accelerators, such as the Large Hadron Collider (LHC) at CERN. Scientists use the data collected from these experiments to study the properties of the Higgs boson and determine its mass.
4. What factors affect the Higgs mass?
The Higgs mass is affected by the strength of the Higgs field, which is responsible for giving particles their mass. The Higgs field interacts with other particles, causing them to acquire different masses. The strength of this interaction can vary, thus affecting the Higgs mass.
5. Why is the Higgs mass important?
The Higgs mass is important because it helps us understand the fundamental structure of the universe. It plays a crucial role in the Standard Model of particle physics and its discovery has confirmed our current understanding of how particles acquire mass. The Higgs boson and its mass are also linked to other important phenomena, such as the stability of the universe and the nature of dark matter.
  • High Energy, Nuclear, Particle Physics
