High Jump Physics: Leaping 1.55m with 0.70m/s Speed
In the high jump, the transformation of kinetic energy into gravitational potential energy is crucial for achieving height. To determine the minimum speed required for an athlete to clear a height of 1.55 meters while leaving the ground with a speed of 0.70 m/s, the kinetic energy equation is applied. The initial kinetic energy must equal the sum of the potential energy at the peak and the kinetic energy during the jump. A calculation error was identified, specifically in the square root operation, leading to an incorrect speed result. Correcting this mistake is essential for accurately determining the necessary takeoff speed.
Morgan89
In the high jump, the kinetic energy of an athlete is transformed into gravitational potential energy without the aid of a pole. With what minimum speed must the athlete leave the ground in order to lift his center of mass 1.55 m and cross the bar with a speed of 0.70 m/s
I have tried solving this problem by using the formulas for kinetic and potential energy. I thought that the initial kinetic energy would equal the potential energy plus the kinetic energy in the air.
KE = PE + KE'
.5(m)(v^2) = m(g)(h) + .5(m)(v^2)
Then i figured i could cancel out mass since it is in all parts
.5(v^2) = (9.81)(1.55) + .5(.7^2)
v= Sqrt (15.205 + .245)
v = 30.9
This is the wrong answer, and i am not sure what i am doing wrong. Please help.
Did you actually take the square root? It doesn't look like you did.
Thank you. that was the problem! Appreciate it!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
