What is the Best High-Temperature Sealant for 1000oF without Copper?
For high-temperature applications requiring a sealant that withstands up to 1000°F without copper, options like RTV style sealants are recommended. Users suggest exploring products from Deacon and Copaltite, which have been successfully utilized in similar conditions. The discussion highlights the importance of ensuring the sealant is metal-free for compatibility. Recommendations emphasize checking the specifications of each product to confirm temperature resistance. Overall, several viable alternatives exist for high-temperature sealing needs.
cstoos
Does anybody know of a RTV style sealant that can handle constant temperatures in the range of 1000oF?
Oh, and it cannot be copper based. Thanks.
Can you use a metal/metal seal?
Try this website. My company has used this before with great success.
http://www.deacontech.com/products.html
Thanks
Matt
Copaltite might work for you.
http://www.escopro.com/copaltite-sealants.html
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
