Highpass Filter Selection for Blocking 60 Hz & Beyond
  • Thread starter Thread starter m718
    Filter
The discussion focuses on selecting a highpass filter to effectively block 60 Hz while allowing some attenuation up to 250 Hz. Participants highlight the importance of defining constraints such as filter order, type (passive or active), and gain tolerance in the passband. Suggestions include using two Butterworth filters to achieve the desired frequency blocking. A user shares their experience with notch filters failing to adequately block 60 Hz, leading to questions about circuit design and potential alternative interference sources. The conversation emphasizes the need for clear specifications and circuit schematics to troubleshoot filtering issues effectively.
m718
Which type of highpass filter attenuates best?
I want to block 60 hz but its ok if there's some attenuation up to 250 hz.
I can't use notch filter.
Depends on what you mean by "best". What are the constraints on your filter? What order filter? Passive or active? Gain tolerance in the passband? Tolerance on the corner frequency?
You could use two Butterworth filters, highpass and lowpass (the order depends on you constraints as berkeman said) and choose their cutoff frequencies such that the 60 Hz frequency is blocked.
I made three different notch filters to block 60 hz from pickup coil that goes to a single opamp amplifier, I put the filter before the amplifier and it doesn't blockout 60 hz, it just attenuates all frequencies about 10%. why is this happening?
Please post a schematic if you can. Also, maybe the 60Hz pickup is getting into the circuit some other way?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
