What is the Time and Distance for a Hockey Player to Catch Up with an Opponent?
  • Thread starter cbrowne
  • Tags
    Physics
In summary, in this problem a hockey player is trying to catch another player with the puck on a frozen pond. The first player starts accelerating at 3.8 m/s2 after 3.0 seconds, while the second player is moving at a constant speed of 12 m/s. To find the time it takes for the first player to catch the second, we use the position equations and set them equal to each other. We get a quadratic equation which we can solve to find the time, which is 11.53 seconds. However, this is the time from when the second player passed the first, so we must add the initial 3 seconds to get the total time of 14.53 seconds. To find the distance,
cbrowne
30
A hockey player is standing on his skates on a frozen pond when an opposing
player skates by with the puck, moving with a constant speed of 12 m/s. After
3.0 s, the first player makes up his mind to chase his opponent and starts
accelerating uniformly at 3.8 m/s2. (a) How long does it take him to catch his
opponent? (b) How far does he travel before he catches up with his opponent?
The position of player #2 is given by
x2 = x2i + v2i t + (1/2) a2 t2
x2 = (12 m/s) t
Equation: x1 = x1i + v1i (t - 3 s) + (1/2) a1 (t - 3 s)2
x1 = 0 + 0 + (1/2) (3.8 m/s2) (t - 3 s)2 = (1.9 m/s2) (t2 - 6 s t + 9 s2)
x1= x2
1.9t2- 11.4t+17.1=12t
1.9t2-23.4t+17.1=0
Now we plug these numbers into the quadratic equation and we get:
11.53 seconds
So the answer for PART A is 11.53 seconds.
b)
x2 = (12 m/s) t
x2 = (12 m/s) (11.53 s)
x2 = 138.36 m
The answer for PART b is 138.36m
Hi cbrowne,
x2 = (12 m/s) t
x1= x2
1.9t2-23.4t+17.1=0
11.53 seconds
I don't think this is correct. I believe they want to know how long the first player was in motion before he caught the second player. That is not what t represents in your equations.
thanks for replying. I have no idea what to do or where to start for this question. I was baseing my answer from this website: http://www.ux1.eiu.edu/~cfadd/1350/Hmwk/Ch02/Ch2.html
if you scroll to the bottom its pretty much the same question but instead of 3.8 m/s its 4.0 m/s.
Any help would be greatly appreciated.
The question is when do you start the clock? When they say how long does it take for the first person to catch the second, do they mean how long from the time the second person passed the first, or how long from the time the first person began chasing him?
From the way the question is worded, I think it means that they want to know how long the first person was moving; what you found was how long the second person was moving (after he passed the first). There is a three second difference between those times.
Related to What is the Time and Distance for a Hockey Player to Catch Up with an Opponent?
1. What is the role of friction in hockey?
The role of friction in hockey is to provide resistance against the motion of the puck and players, allowing for control and maneuverability on the ice. Friction also helps players stop and change directions quickly.
2. How does the mass of a hockey puck affect its speed?
The mass of a hockey puck affects its speed because of Newton's Second Law, which states that the acceleration of an object is directly proportional to its mass. Therefore, a heavier puck will require more force to accelerate and will not travel as fast as a lighter puck.
3. How does the angle of a hockey stick affect the trajectory of the puck?
The angle of a hockey stick affects the trajectory of the puck because it determines the direction and force with which the stick will hit the puck. The angle also affects the spin and lift of the puck, which can alter its path in the air.
4. What is the physics behind a slapshot in hockey?
A slapshot in hockey involves transferring kinetic energy from the player's stick to the puck, resulting in a high-speed shot. The player swings the stick with a large force, creating an impulse on the puck, which causes it to accelerate and gain speed.
5. How does the shape of a hockey stick affect its performance?
The shape of a hockey stick affects its performance in several ways. A curved stick can increase the speed and accuracy of shots, while a straight stick is better for stickhandling and passing. The flex and length of the stick also play a role in its performance and can impact the force and accuracy of shots.
10K
