Calculating Delta-V in Hohmann Transfer Equation
  • Thread starter Thread starter Solistics
Calculating delta-v for a Hohmann transfer using the provided equation led to an unexpectedly small result of 0.00122149 m/s. The issue stemmed from an incorrect value for the gravitational parameter (μ), which should be calculated as GM, where G is the gravitational constant and M is the Earth's mass. The correct value for μ is approximately 4.651 x 10^14 m^3/s^2. Adjusting this value will yield a more accurate delta-v for the transfer. Proper calculations are essential for accurate orbital mechanics results.
Solistics
I'm having some slight difficulties in calculating the delta-v in a hohmann transfer equation. I used the equation from wikipedia (which i hope is correct) but whenever i replace the variables i get an extremely small delta-v, is this normal?
\Deltav=\sqrt{}(\mu/r1)*(\sqrt{}(2*r2/(r1+r2)-1))
r1=6374000 meters
r2=405500000 meters
\mu=9.814
my final result was 0.00122149m/s
it seems like a really small number, is this right or I'm i doing something really wrong?
i attached an excel sheet to show you my work.
thanks in advance
Astronomy news on Phys.org
r1=6374000 meters
r2=405500000 meters
\mu=9.814
thanks in advance
The problem is your value for \mu
\mu = GM
Where G is the universal gravitational constant and is equal to
6.67300 × 10-11 m3 kg-1 s-2
and M in this case is the mass of the Earth, or 5.97 x 1024 kg
so
4.651 X 10^{14}m^3 s^{-2}
thanks for that correction.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
