GulfOnBoard
- 6
- TL;DR
- Homemade aerosol spray can
Hello. I want to make a own refillable aerosol spray can, but I don’t know really how to do it.
I’ve seen quite a few videos/tutorials on youtube where people attach a bicycle valve with epoxy to a spray can and use compressed air to pressurize it.
But I want the gas to be compressed/liquified, so that the pressure remain constant when emptying the can (compressed air drops from high pressure to low pressure fast and takes up much space inside the can). I found out that propane may be the gas that I’m looking for, since it has very good abilities to be compressed/liquified inside the can.
Propane melts at −42°C / −43.67 °F which means that the spray can will be able to operate even in very cold environments, which is good. The product I will use will be based on denatured alcohol so it will not freeze.
But, how do i realize this idea? I thought about using a pipe nipple with threads in both ends as the main spray bottle, then using pipe end caps with thread seal tape to enclose it.
Attaching a spray can valve/nozzle (from a old spray can) to one cap and attaching a propane adapter to the other.
So, in order to fill the can; close a cap, poor down the product (liquid) and close the other cap, put the can into the freezer, take it out and pressurize the can with propane through the adapter (a calculation by weight need to be done in order to know how much propane to fill the can with). That’s it.
Or is it? Do I need to create vacuum inside of the spray can before pressurizing it with propane? Does the environmental temperature integrate with the weight of the propane? Is there any other issue I need to be aware of?
