Homework help for mastering physics
The discussion focuses on a physics problem involving an 85 kg baseball player catching a 145 g ball while leaping. Participants suggest that the solution involves the conservation of angular momentum, particularly in the context of an inelastic collision. To solve the problem, one must consider the player's body modeled as a uniform solid cylinder and his arms as thin rods, calculating the angular speed about a vertical axis. The conversation highlights the importance of applying the principles of angular momentum to determine the player's angular speed after the catch. Overall, the problem emphasizes the application of physics concepts to real-world scenarios.
jesi007
An 85.0 baseball player who has leapt vertically into the air to catch a line drive catches the ball as it is headed horizontally directly into his glove. The ball has a mass of 145 and is headed perpendicular to his arm at 52.0 just before he catches it.
Just after he catches the ball with his arm extended horizontally, what is the player's angular speed about a vertical axis through his head and feet, assuming that he was stationary at the instant he caught it?
To make the calculations reasonable, you can model the player's body as a uniform solid cylinder of mass 73.0 and diameter 35.0 and his arms as thin 6.00 rods, each 70.0 long, pivoting around a vertical axis through his center.
Please help me with this homework problem someone! I believe this deals with conservation of angular momentum but please help me out on how to work this out. Thank you sooo much for you help!
