Solving for Force with Hooke's Law: What Am I Doing Wrong?
A spring with a spring constant of k=45 N/m is initially stretched to 0.35m by a 1.0 kg mass, but the correct length of the spring when the mass is removed is 0.13m. The user struggles to reconcile the calculations using Hooke's Law, F = -kx, and is confused by the force values derived from the spring's stretch. They calculate the force for both lengths but find discrepancies when comparing to the expected mass of 1.0 kg. The discussion highlights the importance of understanding the relationship between force, spring constant, and displacement in applying Hooke's Law correctly. Ultimately, the user receives clarification on the calculations needed to resolve their confusion.
catch.yossarian
A spring with k=45 N/m is .35m when pulled
down with a 1.0 kg mass, what is the length of the
spring when the mass is taken off? The answer in the
back of the book is .13m (13 cm), I can't for the life
of me figure out how they get that.
I know that Hooke's Law is: F = -kx
What I've done so far:
F = (45)(.35) = 15.75 ---> Force it takes to pull down .35 meters, apparently using 1.0kg. Thus, if I divide 15.75 by 9.81, I should get 1.0kg, yes?
15.75 / 9.81 = 1.60 ---> :bugeye:
I must be doing something wrong, let's start backwards.
F = (45)(.13) = 5.85 --> Force it takes to pull down .13 meters (this x is the answer, but right now I'm trying to find a proper F). 5.85 / 9.81 = .56, again, not 1.0kg. :(
What am I doing wrong? Can anybody point me in the right direction?
Consider the spring without the mass.It has the length x_{0}.When acted by a force,its length is x.Hooke's law says that the magnitude of the force is proportional to the the length the spring is stretched under the influence of the force:
F_{el}=k\Delta x=k(x-x_{0})
Compute the force and \Delta x,then use the expression for the latter to solve your problem.
Daniel.
Got it, thanks!
Man, such a small thing, too.
*sigh of relief*
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
