Why Do Rational Functions Have or Lack Horizontal Asymptotes?
In summary, an equation with a numerator to a greater degree than the denominator has no asymptote because the factors of the denominator must also exist in the numerator in order for the function to be rational. The coefficient of the variable to the highest degree is used for the horizontal asymptote because it remains as a constant when taking the limit as the variable approaches infinity. In some cases, there may also be an oblique asymptote for rational functions with a numerator one degree higher than the denominator.
Painguy
120
This is just a general concept question. Why is that an equation with a numerator to a greater degree than the denominator has no asymptote & the opposite does? Also why is the coefficient of the variable to the highest degree the horizontal asymptote? Maybe a proof would help here :P Anyway thanks in advance.
If the numerator had a degree greater than that of the denominator, you could simply divide it down until it was no longer rational.
The coefficient of the highest degree is used (and important) because of the way limits work I suppose. If you divide everything by the highest degree variable in the denominator, you will find that all of the parts of lesser degree will end up with a variable in their denominator. If you "take the limit" as the variable goes to +/- infinity (just imagine that x gets bigger and bigger and bigger), you will find that these parts with a number on top, and a variable on the bottom get smaller and smaller until they basically become zero. Thus, only the leading coefficients remain (as constants) and thus play a role in the H-asymptote. I hope that helps.
This is a really good question, which you will explore more in Calculus I.
Actually, for rational functions (polynomial divided by another polynomial) that has 1 degree higher in the numerator than the denominator, there exists a oblique asymptote (slanted).
For example, the function
[tex]f(x)=\frac{ax^2+bx+c}{dx+e}[/tex]
can be converted into
[tex]px+q+\frac{k}{dx+e}[/tex]
by using polynomial division or other similar methods. This second form clearly shows that f(x) approaches px+q as x gets large positively or negatively.
This is true only if each factor of the denominator also happens to be a factor of the numerator.
So for example if the denominator had the factors (x+1) & (x+3) both these factors would have to be able to be a factor w/e is on top? Could you possibly show an example please :P
If you have a rational function with the quadratic polynomial (x+1)(x+3) in the denominator and you can cancel out the factors so it's no longer rational, that means the factors (x+1)(x+3) must exist in the numerator too (else you can't cancel them out fully, and as I showed in post #3, the value of k would be non-zero).
Examples:
[tex]\frac{(x+1)(x+3)}{(x+1)(x+3)}=1[/tex]
[tex]\frac{(x+1)(x+2)(x+3)}{(x+1)(x+3)}=x+2[/tex]
[tex]\frac{p(x)(x+1)(x+3)}{(x^2+4x+3)}=p(x)[/tex]
And remember, if these examples are functions, then for the second for example, you need to explicitly state that the function is equivalent to [itex]x+2, x\neq -1,-3[/itex].
FAQ: Why Do Rational Functions Have or Lack Horizontal Asymptotes?
1. What is a horizontal asymptote?
A horizontal asymptote is a line that a function approaches but never touches as the input values get larger or smaller.
2. How do you find the horizontal asymptote of a function?
To find the horizontal asymptote of a function, you need to take the limit as x approaches positive or negative infinity. If the limit is a finite number, that is the equation of the horizontal asymptote. If the limit is infinity or negative infinity, there is no horizontal asymptote.
3. What does it mean if a function has a horizontal asymptote?
If a function has a horizontal asymptote, it means that the output values of the function will approach a certain value as the input values get larger or smaller. This can help us understand the behavior of the function as the input values become very large or very small.
4. Can a function have more than one horizontal asymptote?
Yes, a function can have more than one horizontal asymptote. This can occur when the function has different behavior as the input values approach positive or negative infinity. For example, a function with a slant asymptote may also have a horizontal asymptote at a different value.
5. How can horizontal asymptotes be used in real-life applications?
Horizontal asymptotes can be used in real-life applications to model and predict behavior in various situations. For example, in economics, a horizontal asymptote can represent a limiting factor in a business model, such as the maximum profit that can be achieved. In physics, it can represent the terminal velocity of an object falling through the air. In biology, it can represent the carrying capacity of a population in an ecosystem.
