Horizontal bar is used to support a 75-kg object between two walls
  • Thread starter Thread starter PHYSStudent098
    Horizontal Support
A horizontal bar supporting a 75-kg object between two walls relies solely on friction at the ends to maintain equilibrium. The coefficient of static friction between the bar and the walls is 0.41, which is crucial for calculating the minimum force F required to keep the system at rest. To solve the problem, it is essential to draw a diagram illustrating all forces acting on the bar. Participants in the discussion emphasize the importance of visualizing the forces to understand the dynamics involved. The focus is on determining the minimum force needed for stability in this friction-dependent setup.
PHYSStudent098
A horizontal bar is used to support a 75-kg object between two walls. The equal forces F exerted by the bar against the walls can be varied by adjusting the length of the bar. Only friction between the ends of the bar and the walls supports the system. The coefficient of static friction between bar and walls is 0.41. Find the minimum value of the forces F for the system to remain at rest.
I do not have an idea as to where I should start. Thank you.
Draw the dagram. Mark in the forces, all of them.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
