How are smells created and mediated?
  • Thread starter Thread starter ScienceNerd36
Smells are created through a chemosensory mechanism where diffused atoms or molecules from substances reach olfactory receptors, which then transmit information to the brain. The discussion highlights that while cooking can release smells due to boiling water pushing out other atoms, this does not account for smells from non-cooking sources, such as a brass handle. Understanding the physiology of smell is crucial to grasp how various substances emit odors, as each substance has a specific vapor pressure that contributes to its scent profile.
ScienceNerd36
I was recently thinking about how smells are created and came to the conclusion that when you're cooking the boiling water pushes out other atoms before it.
I then realized that this idea doesn't explain the smell that comes off of a brass handle for instance.
Hence the question: How are smells created and mediated?
Chemistry news on Phys.org
Uhm.
Perhaps you should understand the physiology of smell first - smell is essentially a chemosensory mechanism. Diffused atoms - every substance has a vapor pressure - reach olfactory receptors, which send information to the brain.
kldickson said:
Diffused atoms
Let's hope you meant molecules...
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
